Originally Posted by M Engineer
The pump is only one amp. I would bet that the relay would handle that but he need to check to be sure.
Looking at the relay again I concur it
could handle it. But this is a motor load and a small contactor with OL protection (the OP has not told us if the pump has internal OL protection or not) is what he should use. The relay should be used to switch the load, not start and carry the load. Just my opinion and how I would proceed.
Originally Posted by pondo
thank you so much zappa - you made my day. @dmxtothemax - thanks to you too. i will get a bigger relay
No. Keep the relay and get a small contactor with OL protection. The pump will be in the well. The OL protection should be where you can access it.
Originally Posted by Missouri Bound
The motor will draw more on start up...but it won't draw 10 times it's operating voltage. Motors rarely draw more than 2 to 3 times their operating amperage on startup..and that's a 10 amp relay.
Motors can draw up to 8-10 times their full load current on start. This depends on the motor design and the load. This is why I suggest the contactor using the relay to control it. Not to use the relay to carry the starting and running current of the pump motor.
While this relay
could do this, it is not advised. I would not count on the relay to last very long at all. We also do not know the amount of cycles. How many times a day or how many times an hour the relay will be relied upon to do something it is not intended to do. A contactor is intended for this operation and will have electrical and mechanical operations for the lifetime of the contactor available from the manufacturer.
