Old 03-06-2012, 02:01 PM   #16
help needed with relay switch
Originally Posted by pondo View Post
the coil is 8A 250V
I do not think that is the correct coil spec.
M Engineer is offline   Reply With Quote
Old 03-06-2012, 02:07 PM   #17
Missouri Bound's Avatar
He lists the pump at 220 watts. That relay will surely handle that load. I'd
Do you want it your way or the right way?
Old 03-06-2012, 02:52 PM   #18
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would mount all your parts except for pump and float switch in something like this. I use this one for my fish tank to protect my controller and everything that is plugged in with GFCI.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-06-2012, 03:41 PM   #19
that box looks good rrolleston. i will definately be putting everything in a water tight box mounted on the wall. it will end up looking and being like a professional job.
let me explain......
the house where i need to install the pump system is rural. its rural eastern europe so things are done a little different here. when i bought the place i had the villages local drunk electrician replace all the wiring in the house as it was shocking. after that i re-did it all myself. i have learnt that if you want something done properly here..... do it yourself. this is why i insist on learning through forums etc. how to do this myself. i can go and get the drunk electrician as he has done all my neighbors houses, but i dont want to bother re-doing some one else's bad quality job.
sooo, if i buy a hgher spec relay will some-one please explain to me how to connect it? .... maybe with a simple diagram?
btw - what would happen if the relay weren't up to the job. would it pop and burn or would the mains trip switch trip first?... just curious
pondo is offline   Reply With Quote
Old 03-06-2012, 07:06 PM   #20
A "Handy Husband"
rjniles's Avatar
Originally Posted by M Engineer View Post
The pump is only one amp. I would bet that the relay would handle that but he need to check to be sure.
Are you sure about the pump specs, a pump that draws only 1 amp sounds like an aquarium pump.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 03-06-2012, 08:01 PM   #21
rrolleston's Avatar
When you get the pump I am sure someone around here can advise you depending on what specs the pump come with.
Old 03-06-2012, 08:10 PM   #22
rrolleston's Avatar
Thanks it's nice to have because when cleaning, draining and filling the tank during maintenance there are those times when you make a mistake and splash the water or spray something when removing the quick disconnects from the filter. I can have the control pad outside but I just leave it inside because I rarely have to mess with any settings.
Just before maintenance I test the GFCI and turn the filter off.
Old 03-06-2012, 09:30 PM   #23
I was just going off of the OP specs. If it is 220 watts at 220 volts it is 1 amp.
Old 03-07-2012, 01:20 AM   #24
yes im sure about the pump specs. the pump actually pumps water from a depth of 41meters. i have 3 of them(one is always in for a service). they are not the most reliable but do a good job of increasing your borehole water capacity as they vibrate and loosen the mud down there to give you bigger water yields. they seem to handle the mud(works with a diaphram) and are relatively cheap compared to centrifugal pumps which cannot handle any dirt in the water.
saying this tho - i will be changing them for the centrifugal pump as soon as no more dirt(mud) comes out of my borehole. so eventually that relay will be too small. and i would need to upgrade it. maybe i should do it now then.
help needed with relay switch-220w.jpg   help needed with relay switch-water-pump.jpg
Old 03-08-2012, 05:09 AM   #25
The reason why the relay is NOT suitable is ,
whilst the running currant of the pump is only 1 amp,
The starting currant is MUCH higger,
this is what will burn out your relay contacts quite quickly.
And also there are high voltage spikes
when ever motors turn off.
A relay/contactor with at least 30a rating ,
would be a better thing to use.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
pondo (03-08-2012)
Old 03-08-2012, 06:50 AM   #26
This would be a typical double pole relay setup with no safety grounds or fusing shown.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
pondo (03-08-2012)
Old 03-08-2012, 07:35 AM   #27
thank you so much zappa - you made my day. @dmxtothemax - thanks to you too. i will get a bigger relay
Old 03-08-2012, 08:29 AM   #28
Attachment 47202
This assumes the coil voltage equals the input voltage. When you get your new relay make sure it is a 220 volt coil.
The Following User Says Thank You to M Engineer For This Useful Post:
zappa (03-08-2012)
Old 03-08-2012, 10:07 AM   #29
The motor will draw more on start up...but it won't draw 10 times it's operating voltage. Motors rarely draw more than 2 to 3 times their operating amperage on startup..and that's a 10 amp relay.
The Following User Says Thank You to Missouri Bound For This Useful Post:
zappa (03-08-2012)
Old 03-08-2012, 11:51 AM   #30
....10 times it's operating CURRENT....
curiousB is offline   Reply With Quote
Tags
float switch, pump, relay, wiring
Cannot Get New Dimmer Switch Working Correctly BzowK Electrical 8 02-11-2012 05:13 PM
3 way switch replacement in 1923 old house elcc1958 Electrical 3 02-06-2012 09:42 PM
Converting switch to switch & constant power outlet BCeagle08 Electrical 4 01-29-2012 10:34 PM
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 06:56 PM
