Help Needed With Open Ground - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-28-2010, 09:41 PM   #31
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by mark2741 View Post
Thanks oleguy. That makes sense, but I just assumed that since the hot and neutral would be in the same cable/sheathing as the ground, it would work just as well. I was tracing it back to the junction before the GFCI, which is up in the attic I believe, underneath insulation.
You're doing fine. But you have a bad situation for tracing the cable. I would seriously consider just leaving the open ground unless you can find another way to get a new cable (H-N-G) to the gfci from a good equipment ground source.
Do you have any particular piece of equipment your going to plug into that gfci that needs a ground reference? If not then let the gfci be the protection for that outlet and don't lose any sleep over not having a ground. The gfci does not need the ground to function properly.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-28-2010, 09:45 PM   #32
UAW SKILLED TRADES
Stubbie's Avatar
Originally Posted by Yoyizit View Post
Good grounds are called upon to carry current.
You can expect the voltage on ground to rise up to 3 vac or so when passing 10 A through it. Measuring voltage is half the story.
You can check this ground impedance with a hair dryer or toaster or
buy Ideal's 65-165 tester. Just reading the instruction manual for this thing is an education unto itself.
I don't have a financial interest in Ideal's products.
How is all that helping Mark find the location of his open ground ???
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
Jim Port (08-28-2010)
Old 08-28-2010, 09:52 PM   #33
Thanks Stubbie,
I was going to give up on it but then, once I realized I might be able to find the ground wire in the junction/connection in the attic that I assume got disconnected somehow, I tried to give it a go. But it doesn't look like I'm gonna find it so yeah, I'm probably gonna give up now : (
That gfci is in a hall bathroom, above the vanity sink. About the only thing that would ever get plugged into that would be a hair dryer or curling iron (by the wife or daughter, not me : ).
mark2741 is offline   Reply With Quote
Old 08-28-2010, 10:30 PM   #34
Licensed electrician
Rewards Points: 1,242
Are you saying the grounding conductor would only carry 3 volts if a 120 volt wire shorted to the case?
Old 08-29-2010, 12:38 PM   #35
You ask a reasonable question.
With an open ground or similar type problem forum members will be lining up to suggest valid methods to trace this problem.
I doubt they will be lining up to suggest a testing method once the ground is re-established.
Therefore, my post on testing, and many other of my posts on confirming/testing/troubleshooting/calculating expected values, etc.
Old 08-29-2010, 04:10 PM   #36
I think they meant your post did little to actually help the OP with their problem and was off topic.
Easiest way to ground inline surge protectors? wmblalock Electrical 2 03-06-2010 11:07 AM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 09:15 AM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 11:12 AM
