Help Needed: How Do I Ground My Satellite Dish? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 11:20 PM   #16
Electrical Enthusiast
Rewards Points: 504
Originally Posted by stickboy1375
Dish installers are terrible at what the actual code requires, even in the states I see most installations with multiple violations.
I've seen many that are never grounded at all. The installers who did my parents' satellite tv system just draped the coax over the roof, drilled a hole in the wall, and ran the cable through. Looks awful, and no grounding to speak of.
Kyle_in_rure is offline   Reply With Quote
Old 12-29-2013, 12:21 AM   #17
Rewards Points: 6,652
Originally Posted by md2lgyk View Post
A separate ground rod for a satellite dish? Gee, having had a dish in four different homes, I've never seen such a thing. Ground blocks? Of course. Ground rod? Gotta be kidding me.
The wire that travels along the outside of the Coax, is what should be connected to the metal piping of the dish, then connected at the Ground block that the coax is connected to. At the other screw on the ground block, the #10 wire that is used for ground, should be attached to a split bolt, attached to mains ground, or to a strap attached to the Meter pan, or to a ground block for attaching any external communication, Internet, tv grounds, to the mains/Earthing ground to the ground rod, that goes either from the Meter Pan or Main Panel, if required to wire the Earthing ground to the inside panel or main panel, if meter & panel are one unit.
Old 12-29-2013, 06:29 AM   #18
Rewards Points: 3,130
Originally Posted by stickboy1375 View Post
... and you probably had four incorrectly grounded dishes installed, just saying....
Hardly likely. The satellite company installed all of them. If anyone knows the grounding requirements, it should be them.
The Following 2 Users Say Thank You to md2lgyk For This Useful Post:
gregzoll (12-29-2013), Nailbags (12-29-2013)
Old 12-29-2013, 07:52 AM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You mean the same people that put orange cones around their truck when they are parked in your driveway?
The Following User Says Thank You to k_buz For This Useful Post:
jomama45 (12-31-2013)
Old 12-29-2013, 09:13 AM   #20
Licensed electrician
Rewards Points: 1,764
Given that the installers are paid piecework the faster they get done the more they can make. Doing it correctly does not add to the paycheck. They also may have never been taught correctly.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Kyle_in_rure (12-29-2013), stickboy1375 (12-29-2013)
Old 12-29-2013, 09:17 AM   #21
Rewards Points: 348
I asked a guy about that once.
He said that is requires them to walk around the truck to make sure that a kid hasn't left a bike there or something similar since they arrived.
So I understand it from that perspective. What I don't get is why when the back into a parking spot at a restaurant, they put a cone in front of the truck. They are seeing the front as they walk toward it.
herdfan is offline   Reply With Quote
Old 12-29-2013, 09:39 AM   #22
Rewards Points: 42
I used to work for a company that made everyone back in and put a cone in front of their car/truck, including personal cars. The idea is to increase awareness of the surroundings before moving the vehicle and to make passing motorists aware of the parked vehicle.
Dan
djlandkpl is offline   Reply With Quote
Old 12-29-2013, 09:42 AM   #23
joed's Avatar
Rewards Points: 13,322
Big mistake, you will have ground loops if you do not bond the coax to the electrical system.
I do not say not to bond the coax. I said the DISH doesn't need to be bonded unless it is the highest point on the house.
The info about the dish comes from the person who goes around and inspect other install to makesure they meet company standards.
Old 12-29-2013, 09:45 AM   #24
joed's Avatar
Company policy to put out the cones at ALL calls. Makes you walk around the truck to inspect for things like people dropping a bike behind you.
Old 12-29-2013, 09:46 AM   #25
k_buz's Avatar
Can't fix stupid I guess....
Old 12-29-2013, 10:06 AM   #26
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Bwahhhhhhhhh, just the contrary actually, it's a entry level job, the guys are paid pennies, and to be honest, they really DON'T understand the NEC requirements.
Old 12-29-2013, 10:09 AM   #27
E2 Electrician
In the US, they don't have this option, I'm betting Canada follows the NEC pretty closely on this.
Old 12-29-2013, 10:10 AM   #28
Rewards Points: 348
Do they really need to understand them? Shouldn't they be able to just follow a simple procedure as part of the install?
Old 12-29-2013, 10:11 AM   #29
E2 Electrician
Since they are installing something that falls under the NEC, shouldn't they understand them?????? Shouldn't DISH installs require permits since they are dealing with the NEC?
( I understand the OP is from Canada, but a lot of people in this thread are from the US)
Old 12-29-2013, 10:23 AM   #30
k_buz's Avatar
You make an interesting point. Here in WI, we are preparing for mandatory licensing. I was told that this included low volt installations, and that those low volt companies would need permits to install their data systems. I am now curious if that will spill over to CATV/Sat installers?
Sub Panel over 10g-2 Help Needed hamblinh Electrical 30 01-18-2013 07:46 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
