Old 11-17-2010, 08:40 AM   #1
Help need circuit panel box cover
I'm looking for a older circuit panel cover,
14 1/2" x 21 1/2 " panel only has 4 screws, two at the top and two at the bottom.
the panel has bigger breakers as well
kathykobzina is offline   Reply With Quote
Old 11-17-2010, 09:29 AM   #2
Licensed electrician
A brand and model number would help greatly. A pic wouldn't hurt either.
Old 11-17-2010, 08:40 PM   #3
If you can't find one, a tinsmith can make you one.
Old 11-19-2010, 05:21 PM   #4
I took pictures of the panel, how ever i looked every were to locate A brand and model number on the panel. there is none, the only thing i found was on the right side of panel was the numbers 322.
thats all. i hope some one can find out what type of panel I have.
I'm unable to up load the pictures
Old 11-19-2010, 05:51 PM   #5
I=E/R
a7ecorsair's Avatar
Save your pictures on your PC in JPG. Do a reply to this thread and when the window opens, scroll down to Manage Attachments. You should be able to figure it out from here...
a7ecorsair is offline   Reply With Quote
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Murray/Bryant Circuit Breaker and Panel Jfr0521 Electrical 3 06-25-2010 08:49 PM
Need help for circuit panel question vpahandyman Electrical 3 10-09-2009 10:14 PM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
Replace a service panel circuit breaker knockout? michigan_homeowner_2008 Electrical 6 05-22-2008 05:01 PM
