Help!!! My Wife Wants To Buy A New Washer And Dryer - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-20-2009, 09:06 PM   #31
The first thing I think you need to do is check for continuity across the igniter because it is the most likely thing to cause this. I don’t know the exact ohms reading but if it is not open it is more than likely ok. But of course if it is open replace it.
The next thing I would do is run the dryer with the drum out to view the gas valve. To do this you will have to keep the wires to the door switch intact. Also this model may have a belt tension switch, which will have to be pressed for the dryer to start.
What should happen is the igniter should glow red for a few seconds and then cut off and the flame should ignite.
If the igniter doesn’t glow then I would check the thermostats.
If the igniter does glow but doesn’t cut out after sometime (I don’t know the exact time 30 seconds maybe) I would replace the flame sensor (heat detector as some people call it).
If the igniter glows and cuts off but the flame doesn’t iginite more than likely the coils on the gas valve are bad.
If you uncomfortable running the dryer with the drum out you can check the coils with an ohmmeter but it is unreliable because sometimes they check ok ohms wise but still don’t work. Again I don’t know the exact ohms right off. But you won’t be able to check the flame sensor without doing this.
Hope this helps!!
All of this and more is on this page
Last edited by Scuba_Dave; 09-30-2010 at 11:31 AM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Old 10-21-2009, 11:11 AM   #32
Rewards Points: 160
Glad you showed up "applianceman". I really should not be commenting on gas appliances because I don't know sqaut about them. Full electric, I am more comfortable with.
As a matter of fact, I can say I have never seen a gas dryer in my life. (that I know of).
If it worked before you worked on it. You did something wrong.
Old 10-21-2009, 04:23 PM   #33
I may have been too late his wife probably brought a new one.
It would be a shame it could probably be repaired for less than 50 bucks!
Old 10-22-2009, 10:44 AM   #34
Rewards Points: 160
Yes, It looks like hes gone to the store.
Old 10-22-2009, 06:33 PM   #35
Hey guys its a happy ending.
I bought a new ignitor for $50 and it works. Thank you for your help
MikeyP is offline   Reply With Quote
Old 10-22-2009, 07:39 PM   #36
That is a happy ending. You could have come out of this 15 to 20 times that much $$$.
Plumbvoltage is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
Stackable Washer / Dryer Upstairs RammsteinNicCage Appliances 5 04-30-2009 05:23 PM
Relocation of washer and dryer genie Plumbing 2 01-25-2009 02:29 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
