Help!!! My Wife Wants To Buy A New Washer And Dryer - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 01:23 PM   #16
Rewards Points: 58
The continuity test is across the thermostat itself, not the wires. There should be only two terminals on the T-Stat. The easiest way to check this is to jump it out. Across the T-Stat. If it heats jumped out, then the T-Stat is bad. Be careful. Take a picture of the T-Stat and let us see, if you can.
Old 10-15-2009, 10:43 PM   #17
There are four connections on the thermostat
MikeyP is offline   Reply With Quote
Old 10-15-2009, 10:50 PM   #18
" Euro " electrician
frenchelectrican's Avatar
Can you run us the model number of that dryer ?
The reason why I asked here due I know some dryer have couple diffrent connection diagram so I need the model number to be on safe side.
The model number will be in the front of the dryer door when you open up otherwise sometime on the back of unit.
Merci.
Marc
Old 10-15-2009, 11:18 PM   #19
dbxr463gboww
Old 10-15-2009, 11:45 PM   #20
What brand name due I got conflecting numbers show up
Merci.
Marc
Old 10-16-2009, 12:19 AM   #21
Sorry GE
Old 10-16-2009, 12:54 AM   #22
Give me a little time I will come up with wiring chart otherwise I know one person on this fourm he deal with applices and I will paste this link to that part so he can get up to the speed with this matter.
Merci.
Marc
P.S. here the link for this topic in case someone answer it.
one of the fourm member need help with dryer issue
Last edited by frenchelectrican; 10-16-2009 at 12:58 AM. Reason: add a link for dryer issue
Old 10-16-2009, 06:02 AM   #23
the Musigician
DangerMouse's Avatar
http://www.appliancepartspros.com/pa...del_id=5100141
this may help....
DM
Old 10-16-2009, 01:26 PM   #24
Rewards Points: 58
I have never seen four terminals on a element T-Stat. Four wires maybe, but not four terminals. Look at the picture. Do the T-Stats look like these. (sorry best picture I could find) Round with oval shaped mounting bracket. Two screws. Mounted up against the wall of the element/burner housing. If what you are looking at does not look like the pictures, you are looking at the wrong thing. You're model looks to have two of them.
Old 10-16-2009, 08:25 PM   #25
I have the Thermostat off the dryer. The red and yellow connections have continuity but the rest don't. Does that mean its bad. There are definitely four connections.
Old 10-16-2009, 08:36 PM   #26
Ok guys I'm an idiot. I had the drum outlet. I found the thermostat. There are two wires. I took the wires off and there is continuity. So I'm guessing the ignitor must be bad. What do you think??????
Old 10-17-2009, 11:55 AM   #27
Also check the safety (door closed) switch. You should get continuity when the door is closed.
Billy_Bob is offline   Reply With Quote
Old 10-17-2009, 01:26 PM   #28
Rewards Points: 58
Glad you found the T-Stat. Sometimes continuity is not enough to verify it's good. Take the two wires that were on the T-Stat and connect them together, or put a jumper across the T-Stat. See if the dryer heats. This will tell you for sure. You see the T-Stat is just like a switch.
Old 10-17-2009, 04:07 PM   #29
The wires slide onto the thermostat so they have a special end. How do I connect the two wires? Can I twist them together and tape the metal ends together?
Do I have to put the dryer together or is there a way to see if the ignitor is working without putting everything back together?
Old 10-17-2009, 04:21 PM   #30
Rewards Points: 58
Yes, Just for the test. They do make a coupling for the connectors you know? You could just touch them together. Being careful not to touch the terminal ends.
Don't put it back together until you are certain it is working. You only have the back cover off, right?
I do not know about igniter.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 06:29 PM
Stackable Washer / Dryer Upstairs RammsteinNicCage Appliances 5 04-30-2009 06:23 PM
Relocation of washer and dryer genie Plumbing 2 01-25-2009 03:29 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
