Help With My Generator - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 10:29 PM   #16
joed's Avatar
Rewards Points: 12,460
Originally Posted by tibberous View Post
It's a generator. I'm trying to use it as a generator.
Are you saying it's wrong because it's not already single phase?
Yes that is basically what we are telling you.
Old 03-02-2013, 11:31 PM   #17
dmxtothemax's Avatar
Rewards Points: 5,202
It,s hard to see much that helps in that picture.
The red dymo is covering some writting.
And the picture is not straight so we cant
see it too well.
Does the genny have a spec plate and a brand & model ?
Dont take any chances thats a big genny
and it will kill and or burn down houses real quick
if not done properlly.
remember you can weld steel with only 100 amps
so imagine what 200 + amps would do !
picture of spec plate please ?
dmxtothemax is offline   Reply With Quote
Old 03-03-2013, 06:06 AM   #18
Rewards Points: 3,130
I've given up responding to any of this person's threads. In every one, he/she refuses to listen to good advice given by the pros, and insists there has to be a way to do whatever zany thing it is he wants to do.
Old 03-03-2013, 07:25 AM   #19
Rewards Points: 264
Okay guys, I think I got this figured out. Way easier than I was making it, but you have to have a special 3-phase box (TBH, you probably don't and could do it with 2 regular breaker boxes, but they make 3 phase boxes and you can get them on eBay for like $600)
http://shop.neobits.com/square_d_qo3...1034412004.php
And you need to balance the phases or it's hard on the generator, which is why you shouldn't connect a regular breaker box on the outer leads, because you won't be drawing an equal amount of power.
Still not sure the proper gauge of wire so I'm just gonna buy the biggest stuff at home depot and not worry about it.
Still not sure if you are supposed to ground it, probably will to be safe.
Model is a General Motors I 400. 60kw 3 phase and you can adjust the voltage, I'll probably use a multimeter at the box to make sure the voltage is right, because it fluctuates for the first couple minutes it's running.
tibberous is offline   Reply With Quote
Old 03-03-2013, 07:33 AM   #20
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
At the risk of feeding the troll:
Where's your transfer switch or interlock?
Old 03-03-2013, 07:44 AM   #21
Rewards Points: 264
No transfer switch - this is completely separate from the main power.
I'm thinking I should just be able to run from the main breaker on the generator to this box, then be able to treat it like a normal panel box.
http://www.superbreakers.net/qo342mq200rb.html
Breakers for it are expensive as **** (the 20amp ones, 15amp aren't bad) Still, If I can get it hooked up for $1,000, I'll be happy.
Old 03-03-2013, 09:29 AM   #22
joed's Avatar
As a complete stand alone system that is a completely different story.
Old 03-03-2013, 09:39 AM   #23
k_buz's Avatar
If you want a good reason not to give advice to this poster, read this...
Good generator?
If you don't want to waste your time, here are the Cliff Notes....
It seems like NG generators are a little more expensive (both to buy and operate) and don't have the amps to support their watts.
Not really anyone to hear it anyway, and I'm sticking it in a building.
Still not sure what wire to buy. If I want 200amps @ 120vac, do I size the wire for 200amps or 100amps? Isn't it like +120 and -120, so the amps will be split between two wires?
Is the difference between speaker wire, THWN, ect. just the shielding? They have this stuff for cheap but it's aluminum - just don't want it to melt: http://www.ebay.com/itm/250-1-XHHW-A...item2314fddae5
From reading other posts, I get the distinct impression this is an illegal pot farm and he is trying to keep his energy consumption under the radar.
Old 03-03-2013, 01:40 PM   #24
Well, that would certainly explain a lot. Perhaps he's been sampling his product?
Old 03-03-2013, 02:38 PM   #25
Rewards Points: 196
Maybe he is a very generous homeower who would like to supply power to the whole block during a power outage.
HVACTECH96 is offline   Reply With Quote
Old 03-03-2013, 02:50 PM   #26
Electrical Enthusiast
Rewards Points: 504
Not with the price of gas!
Kyle_in_rure is offline   Reply With Quote
Old 03-03-2013, 04:12 PM   #27
Engineer
Rewards Points: 161
That's gonna be some expensive product using a generator for electrical needs!
diystephen is offline   Reply With Quote
Old 03-03-2013, 05:10 PM   #28
What is it with you guys and pot ?
If you suspect anything is even a little sus,
you automatically brand them as pot growers ?
It's presumptious and dangerous legally !
Old 03-03-2013, 05:18 PM   #29
Use of the three phase genny would be possable
if you had a stand alone 3 phase distro board,
But how would you tie this in with your house ?
you would need either a lot of extention cables,
or a complex re organisation of your main panel
which would have to done by an electricain.
Old 03-03-2013, 08:58 PM   #30
As I implied in my earlier post, this person is a clueless whackjob who wants to do whatever he wants despite expert advice to the contrary. If he's not a troll, he's sure close.
Generator & Interlock Kit Float the Neutral? Arnold Ziffel Electrical 12 01-13-2013 05:28 PM
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 10:15 PM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
