Help My Fuse Box - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-17-2008, 01:08 PM   #16
and there has been no rewireing and no floods
Sgt. Pepper is offline   Reply With Quote
Old 12-17-2008, 01:19 PM   #17
Unhappy
no one can help?
Old 12-17-2008, 01:19 PM   #18
Rewards Points: 2,350
So, when the dryer fuses blow, does anything else in the house stop working? A dryer should not be blowing 30 A fuses if it's on its own circuit. I'd try tightening up the connections from the main panel to the small dryer panel and the receptacle. If you have a meter, you should also check the voltage both with and without the dryer running. It should be around 240 V without the dryer running and only a little less running.
After that, I would suspect a malfunctioning dryer. I'm not sure which is cheaper, electrician or appliance repair man, but which ever costs less, I'd call them first.
Can you get us a picture of your main box and small dryer box?
Old 12-17-2008, 01:22 PM   #19
alright thanks man, I'll give it a try.
Old 12-17-2008, 01:22 PM   #20
i'll try to get a picture, one second
Old 12-17-2008, 01:28 PM   #21
i can't get a pic i can't find the digital, i'll have to wait untill my sister comes home with her phone. i might just start a new thread tonight when i have a pic
Old 12-17-2008, 04:25 PM   #22
Rewards Points: 886
Where are the fuses that are blowing? In the box next to the dryer, or in the main fuse panel?
What else shuts off when the fuses blow?
If other appliances also shut down when the fuses blow, then the circuit is not wired correctly. The dryer needs to be on its own 30A, 240V branch, which uses two fuses in the main panel. There may or may not be two more 30A fuses in the box next to the dryer.
The laundry room should have the dedicated circuit for the dryer (240V, 30A), another for the washer (20A, 115V), and yet another for the refrigerator or freezer. The fridge doesn't need to be on its own circuit. You just don't want it on the same as the washer, since it would be more likely to blow, and you lose the food in the fridge if it's out for a while.
Please post photos. It helps a whole lot!
If you are unfamiliar on how to post a photo, let us know.
Ultrarunner2017 is offline   Reply With Quote
Old 12-17-2008, 08:12 PM   #23
Electrical Contractor
kbsparky's Avatar
no one can help?
There is probably no magic formula here. I'd be willing to bet that you simply have an old fuse box that has outlived its usefulness.
Once the internal connections go bad, no amount of tightening of the external lugs will solve your problem.
You might want to figure on replacing that fuse box with a nice new circuit breaker load center.
Old 12-17-2008, 08:24 PM   #24
But first do the troubleshooting.
The worst outcome is that you replace all kinds of stuff and it turns out not to even touch your symptom.
That's why contracts say ". . .will furnish and install. . . " and never say ". . .this will fix the problem."
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
100 Amp Fuse - issue - HELP! Leenders Electrical 9 06-02-2008 04:06 PM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Goodman GMT-070-4 Furnace blows 3A Fuse Bruce Mundy HVAC 4 01-02-2008 10:31 PM
fuse went BANG davej Electrical 1 01-23-2006 12:37 PM
