Help My Fuse Box - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2008, 12:18 PM   #1
help my fuse box
so whenever i run my dryer the fuses burn out within the hour. if i try lower powered ones it burns out faster. can someone help me troubleshoot this. i've even turned off the furnance to dry a load of laundry but it still burnt out on me. I've also tried replaceing both of the laundry room fuses i thought maybe they needed to both be new
Sgt. Pepper is offline   Reply With Quote
Old 12-17-2008, 12:23 PM   #2
Loose connection at the fuse panel causing localized heating which shifts the fuse trip curve downward by a slight amount?
Old 12-17-2008, 12:39 PM   #3
sorry man, you have to dumb it down for me to understand. i know nothing, what is it i should do? Also I'm not sure if they are actually burning out, they are not black or anything like some other disgarded fuses. They just choose not to work anymore or something. Sorry man, can you help me understand what to do? I'd appreciate any help
Old 12-17-2008, 12:40 PM   #4
What size fuses are you using?
jerryh3 is offline   Reply With Quote
Old 12-17-2008, 12:45 PM   #5
Fuses trip because the fuse element melts.
If the fuse environment is very hot the thing will melt prematurely.
Probably 15 minutes into the drying this fuse will feel much hotter than the others, even if the others are carrying the same level of current.
Cut the power if you can, and tighten down the connections near the fuse that is blowing because if there are loose connections they will heat up
and fool the fuse into thinking there is an overload.
If you can't cut the power to the fuse, watch out for shock and "arc flash".
Old 12-17-2008, 12:50 PM   #6
for the size, it's an round fuse not sure what size
Old 12-17-2008, 12:52 PM   #7
Are you sure you're replacing it with the correct size?
Old 12-17-2008, 12:54 PM   #8
all the fuses are the same, same boxes. I'm pretty sure its the same size
Old 12-17-2008, 12:56 PM   #9
we just got three new appliances a washer, dryer and fridge. would that have anything to do with it at all?
Old 12-17-2008, 12:57 PM   #10
Rewards Points: 900
What color are the fuses?
At least in the U.S. fuses are color coded.
Blue for 15A, Red for 20A, and green for 30A.
What was the situation with the dryer before the fuses started blowing?
Did someone rewire anything between the fuse box and the dryer?
Did you have a flood?
Perhaps a photo of the fuse panel would help.
Ultrarunner2017 is offline   Reply With Quote
Old 12-17-2008, 12:58 PM   #11
anything with a possibility of a shock, terrifies me. and I don't know what an arc flash is but the name makes my heart race and my palms sweat so I don't think I'm going to try that one myself
Old 12-17-2008, 01:00 PM   #12
oh you meant amps? I'm sorry guys I'm so dumb. the laundry room is running on 30's
Old 12-17-2008, 01:00 PM   #13
Rewards Points: 900
Yea, if you're trying to connect them to the same wiring that the old were connected, you might be overloading the circuit.
You're not trying to run a dryer on a circuit with anything else, are you?
The dryer (assuming it is an electric appliance, not a gas one with an electric motor), requires its own branch circuit, and it is usually 220V, 30A, requiring two 30A fuses or circuit breakers.
Old 12-17-2008, 01:03 PM   #14
the situation with the dryer is, our dryer was ld and stopped working we bought a new one, when e originally hooked it up it didn't work and we switched both fuses and it worked, the next day we did laundry up untill the evening then the heat stopped working. so we replaced both fuses with new ones and it starts working for a while, then shuts off. and in order to keep the tumbler and heater working is to replace both fuses with new ones, but thats a lot of money for a load of laundry
Old 12-17-2008, 01:05 PM   #15
i think the dryer is on its own circut branch or whatever it has its own metal box that is attached with a metal tube to a bigger metal box on top of it
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
100 Amp Fuse - issue - HELP! Leenders Electrical 9 06-02-2008 04:06 PM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Goodman GMT-070-4 Furnace blows 3A Fuse Bruce Mundy HVAC 4 01-02-2008 10:31 PM
fuse went BANG davej Electrical 1 01-23-2006 12:37 PM
