Help Mounting Junction Box! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 03:03 PM   #1
macon, ga bibb county
Rewards Points: 150
Help mounting junction box!
Hey guys I have been trying to mount this stupid box for about 2 hrs and I don't know how to get it where the bushing will end up flush all the way around inside the box. I also have been looking for different fittings and nobody carries anything but a 90 a 45 and an lb. I don't know if I'm missing something or what. Does the it even need a bushing or can it just enter at an angle and be chalked around? It's not for a splice it's just to exit Sheetrock and make a 90.
Lupus71 is offline   Reply With Quote
Old 04-04-2013, 03:04 PM   #2
Rewards Points: 150
Old 04-04-2013, 04:00 PM   #3
Rewards Points: 13,456
What do you intend to do with this box?
Just use flexable conduit.
Old 04-04-2013, 04:00 PM   #4
Electrician
Rewards Points: 792
Not possible.
The wall is open why can't you recess it in the wall?
darren is offline   Reply With Quote
Old 04-04-2013, 04:07 PM   #5
Rewards Points: 150
I'm just trying to exit the wall and make a turn to the next wall. Everybody told me to get this big a$$ box. I can't seem to get the conduit square with the wall to hook an lb up or this box. Can I just run conduit straight out of the wall and chalk around it? Is that up to code?
Old 04-04-2013, 04:10 PM   #6
Electrician
Rewards Points: 792
What are you trying to do this with this pipe, i noticed you are using PVC. Is there a reason you need PVC.
Old 04-04-2013, 04:11 PM   #7
How about you let us in on the whole plan for better advice.
No clue who would have suggested using a box for this simple job.
Old 04-04-2013, 04:17 PM   #8
Rewards Points: 150
I'm running power to a shop in the backyard. It will be 2-2-2-4. I am trying to come from my existing sub down and out the Sheetrock then over to the next wall to exit to outside. I'm using PVC because I didn't think it mattered and it is cheap. I have a 12x12x6 box and 2" fittings.
Old 04-04-2013, 04:18 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
No way are you going to get the 90 to fit that box flush.
Are you going to put the sheetrock back?
I would try 2 back to back 45's and come into the top of the box.
Old 04-04-2013, 04:20 PM   #10
The following answer is based on your limited explanation - What I understand is that you don't even want to use that large junction box but want to exit the panel and then turn that PVC 90* elbow so it comes out of the wall and then head towards another wall. All of that and you need the PVC to be flush with the wall.
What I would consider is turn the 90* elbow until it won't turn anymore because of interference from studding and or sheet rock. Then take a PVC blanket heater and put it on the end of the elbow and let the PVC get soft. Then hand form the Elbow so it follows the wall. Be careful not to collapse of kink the PVC.
I assume you will be continuing that conduit run so it might be a good idea to put an extension piece onto that PVC elbow before you heat it up. Otherwise you may end up deforming the end of the elbow.
If you want to use that junction box, use some flexible conduit instead of that PVC elbow.
parman is offline   Reply With Quote
Old 04-04-2013, 04:23 PM   #11
jbfan's Avatar
Rewards Points: 386
Joe, you have to find his other post about this.
Old 04-04-2013, 04:31 PM   #12
Rewards Points: 150
Yes I am putting the Sheetrock back. I will definitely run the conduit straight out the wall no box or lb if that's ok as far as code. I just thought you couldn't run conduit out of the wall like that. I have never done any electrical work just been reading up on it alot. As far as coming in the top of the box you are also saying run conduit out of the wall then angle down into the box right? So I assume its ok to do that
Old 04-04-2013, 04:37 PM   #13
Rewards Points: 150
Yes I am sorry for posting so many questions about this run. I am just worried I will get all this glued up and ready for inspection and fail then have to scrap my conduit and fittings and take it all back apart to fix something I may do wrong. I just cannot afford an electrician.i think I can get the rest done if I can just get started out of this d$mn sub panel!
Old 04-04-2013, 05:14 PM   #14
Since you still have not added your location to your profile no one's going to be of much help with any code questions.
Old 04-04-2013, 05:21 PM   #15
Electrician
Rewards Points: 792
I would scrap that pre made 90 and get a stick of 2" PVC. Rent or borrow a PVC oven and bend your own 90. Then kick the 90 over(http://wilderness.hubpages.com/hub/E...w-to-Bend-a-90). Won't be pretty but will do the trick.
Junction box mounting screw question. DangerMouse Electrical 5 07-30-2010 09:19 PM
Mounting Checkolite pot rack with lighting Warner Electrical 2 06-16-2010 01:56 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Mounting junction boxes in attic, are both of these locations acceptable? diymonkey Electrical 33 04-09-2009 07:24 AM
