Old 01-12-2013, 01:53 PM   #1
Help mounting electrical box to irregular surface
I'm not sure which forum is best for this topic but here it is in electrical...
I have a detached 2-1/2 car garage. The facing of the garage is ~3/4" thick deco-stone applique mortared onto mesh lath, and then grouted. The contour of the stonework is quite irregular; below you will see my iPhone perched on a ledge to give you an idea.
I would like to add some supplementary lighting around the garage door openings. Some location options include at the keystones, in between the window and left hand side door, or central (underneath where you see our Christmas wreath currently hung).
My wife favors the central location although I am not 100% sold on this yet. She imagines a wrought iron-looking decorative lantern fixture to match the faux carriage hardware on the overhead doors.
My question here is regarding the best way to mount such a fixture to the irregular stone surface. What's the best/right way to do this? I was thinking about building up an area with some mortar so that it was in fact flat, then mounting an outdoor box to it. i was also thinking that i could simply use NM conduit w/threaded fittings into the box and not securing the box at all to the wall–– the conduit would hold it in place. This would only entail a ~1" hole in the stonework. I'm not convinced of this idea.
Any ideas and/or thoughts on mounting location and attachment method appreciated.
Note:
In just about any mounting location, the interior area directly behind where the box would go is open for access.
Regards,
Wrooster
ps:
I have used google images and found a couple of photos of this type of application and honestly I think that having such a gap around the mount is a little bit hack-ish...
wrooster is offline   Reply With Quote
Old 01-12-2013, 02:13 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Pressure treated post in the ground, to support the outlet, vs trying to hang it on the wall surface. That will mean teenching for the conduit runs.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 01-12-2013, 04:54 PM   #3
I would go for something like this.
http://culturedstone.com/literature/...xSellSheet.pdf
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
mpoulton (01-15-2013)
Old 01-12-2013, 05:42 PM   #4
gregzoll's Avatar
Problem is Oso954, it is easier to do it when the stone is being applied to the house, than after the fact.
Old 01-12-2013, 06:44 PM   #5
Everything is easier/cheaper if done in the right order during construction.
The important question is how much work/expense is the OP willing to put into mounting the light(s), for the appearance that he/his wife is after.
My read (right or wrong) is the final result is the prime factor.
Old 01-12-2013, 09:57 PM   #6
Licensed electrician
A skilled mason should be able to work a mounting block into the stone. Preplanning would have helped.
Old 01-12-2013, 11:05 PM   #7
Where in my post above does it say anything about an outlet? What does trenching have to do with putting an electrical box on a wall to mount an outdoor light fixture/lantern to?
Wrooster
Old 01-12-2013, 11:12 PM   #8
You guys and your "you shoulda done X first!"
No kidding.
The structure was built in 1922 and initially served as a carriage house. It was converted to an actual car garage somewhere circa 1950. The decorative stone facing was evidently added around 2004. My wife and I bought the house in 2009. Now it is 2012 and I would like more light above/around the garage doors. When, exactly, should I set my time machine to in order to "pre-plan" for this work?
A "skilled mason", good grief. Maybe he could lay a proper foundation as well, and I could just build an entire new garage atop it and pre-plan for the lights.
Wrooster
Old 01-12-2013, 11:37 PM   #9
DIY Enthusiast
sublime2's Avatar
No kidding.
Wrooster
Lmao!
Welcome to diy with a pro.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
gregzoll (01-13-2013)
Old 01-13-2013, 12:26 AM   #10
Child Alert! Pull Up!
fltdek's Avatar
May consider the possibility of using a Carbide Hole Saw to cut through surface enough to mount a shallow round box. Check these out:
http://www.emisupply.com/catalog/car...FQqk4AodMUIA7Q
Might work for you
fltdek is offline   Reply With Quote
Old 01-13-2013, 11:56 AM   #11
It really isn't has hackish as you might think. In reality, you will probably be the only one that notices. I do get that it might bother you, but it is probably your best option.
IMHO, 98% of outdoor fixtures are cheap pieces of crap. The mounting of them becomes secondary to their crapiness.
herdfan is offline   Reply With Quote
Old 01-15-2013, 07:36 AM   #12
Bill Kearney
If you really wanted to make it look right then use an angle grinder to cut out an appopriately sized hole, mount a fresh piece of stone in that hole and drill through that for the wiring. The trick will be in matching the stone and grout colors. Otherwise there are various kinds of mounting boards you could use (or make), and scribe the back of them to fit more cleanly with the existing stone. The correct way to do it, however, would likely be to cut a hole for an electrical mounting box. Either by itself or into a piece of stone also cut to hold it.
wkearney99 is offline   Reply With Quote
Old 01-15-2013, 07:59 AM   #13
Super Moderator
Might work for you
There are services that will cut round holes for you---those tools are expensive---look under 'concrete core drilling' or 'concrete cutting'
A coped wood block could be added to give you a tight fit---
You tube--coping with an angle grinder----
Old 01-15-2013, 09:09 AM   #14
Electrical Contractor
kbsparky's Avatar
A small block of AZAK mounted on spacers would do the trick. You simply use however many spacers you need on each corner to make the block level/plumb.
-KB
Tags
box, lantern, mount, stonework, surface
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
Mounting Checkolite pot rack with lighting Warner Electrical 2 06-16-2010 02:56 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
Surface mounting breaker box Nhrafan Electrical 3 04-09-2008 03:16 PM
