Help Me Wire Up New AC Fan Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2008, 11:51 AM   #1
Angry
Help me wire up new AC fan motor
My fan motor went out on me this weekend and I bought a new one yesterday. I have installed the motor and hooked up the wires to the fan to the unit it worked for 5 Minutes then threw the breaker. I tryed hooking it up a different way and it threw the breaker. I don't know what I am doing wrong. How do I hook up the wires for a Emerson Rescue motor 1/5 Horsepower RPM 1075. I can not figure this thing out.
queenlizzard is offline   Reply With Quote
Old 05-28-2008, 12:35 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
Is this motor for the air handler fan or the condenser fan?
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 05-29-2008, 12:22 AM   #3
Idiot Emeritus
Rewards Points: 1,492
How many wires come out of the motor? What color are they? Is there a capacitor? (Usually an oval-shaped metal thing about 2"-4" long, with 2 terminals on one end). When it runs, does it hum louder that you'd expect? Does it turn the right way? Is there a diagram on the nameplate that lists wire colors, and one of them is labeled 'common', two of them 'capacitor', or 'cap', and the rest something like 'low speed', 'high speed', etc.?
I'm sure full of questions tonight, huh? lol. If it is a multispeed motor and power is applied across two of the speed wires, and not the common, it'll run, hum a bit louder than usual, and draw ALOT of current. Thus the tripping breaker. It could be other stuff though.
Rob
micromind is offline   Reply With Quote
Old 05-29-2008, 08:56 AM   #4
Rewards Points: 566
I did some extensive searching and found zip as far as even a wiring diagram goes. Listen to Rob, though. Sounds like a multi-speed motor application (and I'm guessing that it's your furnace blower) and you've got it wired incorrectly.
You'll want to rectify the problem before running it much longer though to avoid permanent damage to the motor.
Blower Motor Wiring Help atvguy64 Electrical 11 08-14-2015 10:02 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Wiring a Switch for a motor luweee Electrical 6 04-06-2008 12:02 PM
Blower motor wiring help!! atvguy64 HVAC 4 02-04-2008 09:27 PM
