Help Me Please - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 08:32 PM   #1
help me please
i connected the ground wire coming from my breaker box to the hot lead on my 240 volt submersible well pump well i crossed a ground and a hot and tried to check it to see if it would run for less that 2 seconds is there any danger i could burn the motor up
bubbarude is offline   Reply With Quote
Old 06-15-2012, 08:35 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Could you retype that with punctuation and capital letters?
The Following 2 Users Say Thank You to k_buz For This Useful Post:
mpoulton (06-15-2012), Speedy Petey (06-15-2012)
Old 06-15-2012, 08:37 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
I don't get it either.
Speedy Petey is online now   Reply With Quote
Old 06-15-2012, 08:39 PM   #4
what im trying to say is i got the ground wire and one of the hot leads crossed when i spliced the wires on the pump leads
Old 06-15-2012, 08:40 PM   #5
Licensed electrician
Rewards Points: 1,870
I think the OP transposed 2 wires and wants to know if the smoke will come out. Why a ground was used as a hot I can't figure out.
Old 06-15-2012, 08:43 PM   #6
ok i had 3 wires going to the pump and 3 wires on the pump two were the hot leads and one ground by mistake got a hot and a ground crossed what im asking is if you connect a hot wire to the ground lead on a 240 volt motor will it automatically fry the motor
Old 06-15-2012, 08:44 PM   #7
and no smoke came out and no breaker tripped it was just a quick on and off of the switch
Old 06-15-2012, 08:46 PM   #8
k_buz's Avatar
How did you get the hot and ground mixed up? The hot should have been black and the ground should have been bare or green.
That's beside the point tho. Your pump should be fine. Just be thankful you weren't touching the case of the motor when it was energized.
The Following User Says Thank You to k_buz For This Useful Post:
Old 06-15-2012, 08:49 PM   #9
thank you very much and to the how i got them crossed this wasnt my well and someone had used all black wires with no markings i really didnt think it would ruin the motor but i didnt get to finish the job today and have been worried about it
Old 06-15-2012, 08:52 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
So why are you working on it?
Old 06-15-2012, 08:53 PM   #11
k_buz's Avatar
You really should learn to type so people can read what you are writing. You aren't texting your BFF, you are asking adults advice on a (possible) serious issue.
Old 06-15-2012, 08:54 PM   #12
just helping a couple who cant afford to pay someone else and didnt they didnt want to buy new wire
Old 06-15-2012, 08:57 PM   #13
E2 Electrician
okay, so why did you offer if you don't know what you are doing? Im not giving you the third degree, I'm just curious...
Old 06-15-2012, 09:01 PM   #14
Well im sorry i didnt realize this was grammer 101 i just asked a simple question and i did get a answer and i thank you im typing this on my phone its not the easiest thing to type on thank you for your help and ill refrain from coming back until i learn how to properlly type this out thank you fine gents
Old 06-15-2012, 09:06 PM   #15
Missouri Bound's Avatar
....now I get the bubba"RUDE" part.
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
Speedy Petey (06-15-2012), stickboy1375 (06-15-2012)
