Old 12-20-2007, 10:58 AM   #1
Help Me Mod FM Transmitter *pictures*
Hi!
I got this freebie FM Transmitter. It's branded Nordic, model FM-018. I Suppose it's a cheapo with the resellers logo or something. I want to make antenna longer and better but I can't seem to find it. I havn't really messed with electronic components before so your help would be very much appreciated.
Sorry for the crappy light. Hope anyone can help
busharmy is offline   Reply With Quote
Old 12-21-2007, 04:32 AM   #2
I read in a comment on a guide to modify the zune fm transmitter, a guy used a multimeter to detect a better spot to 'weld' an antenna to. If I try that with a multimeter what am i looking for? How can I identify the antenna?
Old 12-22-2007, 09:08 AM   #3
Eibwen
The pictures are kinda hard to see at the resolution needed. Can you do some closer shots at higher res?
The antenna would normally look just like a small peice of uninsulated wire that may have one end unattached to the circuit board. It could also be a chip type mounted on an ic chip.
If its the wire type I would suggest just adding to it versus trying to relocate it on the board. It would be easier to solder with less chance of heat damage to other components.
Sammy is offline   Reply With Quote
TV Cable problems angelaz Electrical 14 08-03-2007 06:59 AM
