Help Making A Switch Controlled Outlet Constant - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2013, 08:52 PM   #1
Help Making a Switch Controlled Outlet Constant
Hi all. I am new to the site and hoping for some help with a wiring issue. I have an electrical outlet that is controlled by a light switch (the switch also controls the overhead lights). I'd like to make the outlet constant and leave the switch to only control the lights.
I removed the boxes for the outlet and the switch and they both look pretty standard, one black, one white, and one ground wire. When I checked the light fixture box, i have three black, two white and two grounds (One of each going to the light fixture).
Does anyone know how i can tweak the wiring in the lights to make the outlet constant? Thanks in advance
admblntn is offline   Reply With Quote
Old 11-19-2013, 09:38 PM   #2
Licensed electrician
Rewards Points: 1,054
If the receptacle just has one cable you will need to find the other end and splice the black to the constant hot.
Old 11-19-2013, 11:00 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
r.e: Above in bold. Are you counting the fixture wires in the above count? Is this wiring in conduit?
Coastal South Carolina
Old 11-20-2013, 08:21 AM   #4
Yes, I am counting the fixture wires when I say there are three of each. I'm not sure about it being a conduit. Would it be possible to replace the toggle switch with a dimmer switch? I was thinking I could dim the switch so that it's basically off, but the power would still go to the light and outlet.
Old 11-20-2013, 08:38 AM   #5
A "Handy Husband"
rjniles's Avatar
It is a code violation to use a dimmer on a switched receptacle (and it will not work like you want).
Tell us how many wires and colors are in the fixture box not counting the fixture wires.
Old 11-20-2013, 09:10 AM   #6
I"ve got two black wires and two white wires that do not go to the light fixture. Each set of these is capped with a third wire which only runs to the fixture.
Old 11-20-2013, 05:04 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,098
If there is only three wires at the switch, including earth,
Then it is most likely a switch loop, which means power
first goes to the fixture.
We need to know more about the wires at the fixture,
How many ? What color ? Where do they go ?
A picture would be very helpful !
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
rjniles (11-20-2013)
Tags
outlets and switches
switch outlet combination phill1 Electrical 4 11-09-2013 09:57 AM
Help wiring a ceiling fan from a half hot outlet controlled by a switch harleydadokc Electrical 3 06-15-2012 01:06 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Outlet controlled by a wall switch rwright46 Electrical 5 04-30-2009 06:00 PM
