10-22-2011, 11:39 PM
#1
HELP! Major problems installing a new light fixture
I installed a new light fixture to a 3-way switch (1 dimmer and 1 on/off switch) and the dimmer blew when I first tried to turn it on. So, I replaced the dimmer and the new light fixture worked for about a day until the new dimmer blew. I decided to replace the dimmer with an on/off switch. I installed the new on/off switch and the breaker trips every time I try to turn it on. I tested the volts in each wire of the switch I've been replacing, and I'm getting 120 volts from the red wire and zero from the both black wires. Any idea what is going on?
Is it possible that the new light fixture is not compatible with the receptacle? It's a 75watt, 120volt, 60Hz AC 4-bulb light.
Would it work to just eliminate one of the 3-way switches so there is just 1 on/off switch? If so, how do I do that?
The photos show the wiring for the switch I've been replacing (single switch) and the other switch (doubled with another switch to a different light; the switch I'm referencing is the one on the left).
I would really appreciate any advice!
10-22-2011, 11:52 PM
#2
I am too tired to troubleshoot, but your switches are not grounded and that is a violation.
10-23-2011, 12:11 AM
#3
Electrical Contractor
How many wires at the fixture, and how is it wired?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
10-23-2011, 12:19 AM
#4
On the light fixture there is a clear wire labeled "N" (we assumed neutral), a clear wire labeled "L" (we assumed live/hot), a ground, and another wire with a green stripe. We hooked the N wire to the white, the L wire to the black, the ground to the ground, and taped the end of the green wire and left it unconnected (because there was no other wire to connect it to).
10-23-2011, 08:14 AM
#5
A "Handy Husband"
I will assume you did not change any wiring in the switch at the box with the 2 switches. At the single switch the black from the 2 wire cable (the one on the right) goes to the common of the switch. The black and red from the 3 wire cable go on the other 2 terminals (travelers) of the switch. Make sure you identify the common of the switch, do not assume because of the position on the old switch. Different manufacturers lay them out differently. Usually the common screw is colored black.
Coastal South Carolina
10-23-2011, 09:13 AM
#6
Electrician
What happens if there are no ground screws on the switches, I know I still see new switches without ground screws.
10-23-2011, 10:07 AM
#7
Licensed electrician
If there are no ground screws on the switch you need to get grounded switches.
10-23-2011, 01:06 PM
#8
Electrician
One more difference between our codes and the NEC.
10-23-2011, 11:46 PM
#9
I wired it the way you said and it tripped the breaker when I turned it on.
10-24-2011, 06:30 AM
#10
A "Handy Husband"
Then something is wrong at the fixture. Describe the fixture wiring and show us a picture. Might be as simple as crosssed wires when you connected the fisture to the box.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
