Help With Low Voltage Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2014, 07:10 AM   #1
Rewards Points: 4
Help with Low Voltage Recessed Lights
So I have a lot of 3 inch recessed electronic low voltage lights. There are as many as 10 on each circuit and they were installed in 2007 so they are halogen bulbs (50 watt).
The way they are wired is from the dimmer switch it outputs line voltage to each recessed junction box, in the junction box is a transformer which lowers the voltage and then runs through a very narrow chase into the actual recessed fixture to the bulb (MR16 50Watt halogen). I am routinely having issues with these lights. The bulbs and/or transformers fail on a very regular basis.
I want to stay with the 3 inch recessed fixtures and I want to achieve (in order of importance):
- Get the lights to work consistently so I can stop changing/replacing parts.
- Get more light in the space.
Some things to note:
- The dimmer switch will get really hot.
- I have tried LED bulbs but they don't work correctly (I am assuming because of the transformer type).
- I have no idea what rating the dimmer switch is but it would have to powerful as it is pushing 500 watts or more.
- I have replaced the dimmer with an electronic low voltage dimmer switch and it didn't seem to improve anything.
Any help is appreciated.
knightsae is offline   Reply With Quote
Old 09-27-2014, 01:16 PM   #2
Oso954's Avatar
Rewards Points: 2,340
What make and model are your lights ?
Are they in contact with insulation ?
Oso954 is online now   Reply With Quote
Old 09-27-2014, 07:56 PM   #3
Rewards Points: 2,974
Your lamps and transformers are simply running too hot !
Heat build up is killing them.
Improve ventilation !
Using LEDs will improve matters as they produce less heat.
But if there is no or little ventilation them even the leds
Will not achieve full life span.
dmxtothemax is offline   Reply With Quote
Old 09-27-2014, 08:30 PM   #4
Rewards Points: 760
Originally Posted by knightsae
So I have a lot of 3 inch recessed electronic low voltage lights. There are as many as 10 on each circuit and they were installed in 2007 so they are halogen bulbs (50 watt). The way they are wired is from the dimmer switch it outputs line voltage to each recessed junction box, in the junction box is a transformer which lowers the voltage and then runs through a very narrow chase into the actual recessed fixture to the bulb (MR16 50Watt halogen). I am routinely having issues with these lights. The bulbs and/or transformers fail on a very regular basis. I want to stay with the 3 inch recessed fixtures and I want to achieve (in order of importance): - Get the lights to work consistently so I can stop changing/replacing parts. - Get more light in the space. Some things to note: - The dimmer switch will get really hot. - I have tried LED bulbs but they don't work correctly (I am assuming because of the transformer type). - I have no idea what rating the dimmer switch is but it would have to powerful as it is pushing 500 watts or more. - I have replaced the dimmer with an electronic low voltage dimmer switch and it didn't seem to improve anything. Any help is appreciated.
You need a special dimmer for magnetic low voltage lighting. This is why your transformers are failing. Cheap dimmers have a DC component which kills transformers. You said you tried an electronic magnetic dimmer. Did you ever have a transformer fail when you used it?
Is the dimmer in a plastic or metal box? Are their other dimmers in the box? You need to derate dimmers when they are ganged.
curiousB is online now   Reply With Quote
Replacing existing recessed soffit lights miamicuse Electrical 35 06-22-2013 07:52 AM
Adding Additional Recessed lights to existing jay235 Electrical 5 11-08-2012 05:43 PM
Recessed lights for the bathroom miamicuse Electrical 14 07-07-2012 09:49 AM
Meaning of Recessed Lights That Are "Not Rated for Insulation"? DoItY Electrical 7 06-30-2012 12:00 AM
Planning the placement of recessed lights buckybadger15 Electrical 3 05-02-2012 03:15 PM
