HELP! Losing Power To Parts Of The House And It Changes Location Of What Goes Out - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 03:26 PM   #1
Exclamation
HELP! losing power to parts of the house and it changes location of what goes out
Losing power to diferent parts of the house and diferent location, and what is effected each time it happens.
Last night it was the front pouch, dish washer (light would go on and off), kitchen lights, dining room, hallway light back bed room, and window ac.
Today it is the Water pump ( for the well), AC, and the Stove (time on stove works but the burners and oven don't),
and the items I stated before are working fine.
this is a WTF thing.
TazerKing is offline   Reply With Quote
Old 05-12-2013, 03:46 PM   #2
Electrical Contractor
kbsparky's Avatar
Call your power company. You may have bad incoming line(s).
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
gregzoll (05-12-2013)
Old 05-12-2013, 03:52 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,770
Sounds like you've (the POCO) lost one hot leg..... with clock on stove working and 240's not working.
Bad news is you can't fix it..... Good news is that the POCO has to
EDIT: Just reread and realized it is not consistant and not constant.... strange???????
MTN REMODEL LLC is offline   Reply With Quote
Old 05-12-2013, 04:23 PM   #4
What would make it a bad incoming line. I cant see my lines they are under ground from the pole to the house?
And the power outage at the house chances places.
Old 05-12-2013, 04:55 PM   #5
Spoke to a friend who owns a electricain and owns his own co.
Spoke to a friend who owns a electricain and owns his own co (Win Electric Brunswick Ga)
Told him of the issue and he told me to call the power co I had lost a Phase.
Thanks kbsparky and everyone else
Ill let ya'll know if that fixed the issue
Old 05-12-2013, 05:46 PM   #6
Tazer.... Yes, cause it seems a leg (or phase) is bad.... but the interesting thing is that you think it affects different circuits each time it occurs. ARE YOU SURE.
If it's a bad leg/phase, the same set of circuits should be going out each time it occurs.
Good luck
Peter
Old 05-12-2013, 05:52 PM   #7
Rewards Points: 1,548
You could have a bad neutral, which would cause the voltage to see saw well above and well below 120 volts.
This needs immediate attenstion as it will burn out equipment and electronics and could even cause a fire.
If you have incandescent lights, those will get abnormally bright (and may burn out quickly).
It is not trivial but also not terribly difficult to find out whether the problem is in the power company lines (call the power company first) or in your own system (call your own electrician first). I am leaning towards calling the power company first if you can't quickly find a problem on your side.
Old 05-12-2013, 06:15 PM   #8
Alan.... That isn't consistant with what Tazer has told us is happening... but maybe your explanation is exactly right.
Maybe Tazer has 1) not noticed the 240 thru his appliances/lighting, and because he has different loads on at different times that his neutral kicks out, it consequently affects different appliances/lighting as the voltage fluctuates differently with different loads in series.
Be interested to know
Old 05-12-2013, 06:48 PM   #9
Rewards Points: 150
the stove was the givaway on the problem when the clock works (120v) and the burners dont(240v) you can usually start looking for a lost phase . things will backfeed thruogh 240 v appliances like the HWH so somethings will work and then they wont .
usair is offline   Reply With Quote
Old 05-12-2013, 07:19 PM   #10
USAIR....Could you explain that to me.... if you loose a leg, it still seems to me that it will be the same circuits affected each time. What does backfeed mean.
Old 05-12-2013, 07:40 PM   #11
Electrical Enthusiast
Rewards Points: 504
Theoretically, If you lost a leg, the remaining leg could feed through a 240v appliance, Such as a water heater, and energize the absent leg in the panel.
Kyle_in_rure is offline   Reply With Quote
Old 05-12-2013, 09:45 PM   #12
Kyle... Thanks, I understand what you're saying, BUT from the OP's description above , it just doesn't make sense to me that a system would display that strange of behavior. Still seems that principly, the same circuts would be affected, with maybe some voltage differences.
Hope we find out
Peter
Old 05-12-2013, 09:47 PM   #13
" Euro " electrician
frenchelectrican's Avatar
There is the other way you can think is the large MWBC which basically 99% of Americianie homes are wired like that way.
So with the 240 volts device when they kick in like water heater or large electrique heater or A/C unit or other high wattage devices like dryer as well.,, it will act like tempory bridge to carry over the 120 volt to the other leg of MWBC but the actual voltage will not be excatally at 120 volts most case useally lower due the restance of heating element or motour.
Now for the OP the only way the POCO will fix this is either use the TDR or Megger to find where is the open splice and dig up the ground and use the underground repair kit.
Some case they will replace the whole underground lateral cable if short run.
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
Kyle_in_rure (05-12-2013), MTN REMODEL LLC (05-12-2013)
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Intermittent Brief Power Outages in Half the House mac70pete Electrical 11 06-02-2011 09:35 PM
Turned off power. Changed outlet. No power to entire house. pauly99 Electrical 39 03-06-2009 05:09 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
