Help With Lighting Short - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2015, 07:33 PM   #1
Rewards Points: 2
Help with lighting Short
I think I have a short in my driveway lights. There are four 100 watt lights attached to a regular 120/240V breaker in our main breaker box. The four lights are the only thing attached to this breaker. They are hard wired with waterproof buried romex stuff. They worked just fine for about 8 years and all of a sudden they trip the breaker. I pulled off all the lamps from the poles and checked all the connected they all looked really good, some of the grounds were corroded but I cut them and put new nuts on. When I turn the breaker on sometimes some of the lights come on for not more than 30 seconds, I can hear a humming building up and then the breaker flips. Seems like there is a short somewhere but I can't get any of my electrician friends to come look at it. The fixtures themselves don't seem very water tight, I'm thinking either the breaker is bad or the fixtures themselves have a hidden short?!? The connections coming to the fixtures underneath in the poles look really good and I can't imagine a short appeared underground... Should I just get new fixtures?
angieandmatt is offline   Reply With Quote
Old 11-06-2015, 07:43 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,478
Turn off the breaker.
Remove all the lamps
from the fittings.
Carefully measure
the resistance across
the hot line to the lights
And the neutral of the same line.
With no lamps there should
No resistance. If there is ?
Then you have a short.
Certainly possable
With underground wiring.
Cause water will get in.
Be careful in the panel:
Take all precautions.
dmxtothemax is offline   Reply With Quote
Old 11-06-2015, 09:33 PM   #3
joed's Avatar
Rewards Points: 13,274
Some of the lights come on? I would turn off the breaker and remove the cable leaving the last light that comes on. Remove the bulbs and measure the resistance of the cable you disconnected. If it measure shorted then you just need to find the problem spot.
Old 11-07-2015, 06:09 AM   #4
Rewards Points: 1,532
Originally Posted by dmxtothemax View Post
...With no lamps there should
Certainly possable
With underground wiring. ...
A wiring short is signified by "no" resistance (practically speaking less than five ohms) with nothing plugged in or turned on.
With no lamps there should be "infinite" resistance between hot and neutral and between hot and ground, practically speaking, more than 100,000 ohms.
There could be intermediate amounts of resistance. If so you should be suspicious because that will result in current leakage in a manner similar to a short circuit which is likely to worsen over time.
Always turn off power before doing ohms or resistance measurements.
AllanJ is online now   Reply With Quote
Old 11-07-2015, 02:48 PM   #5
Rewards Points: 1,428
from the fittings.
Carefully measure
No, there should be infinite resistance. With a short there would be no resistance, or close to it.
poiihy is offline   Reply With Quote
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 02:20 PM
Basement Lighting blaze01 Electrical 1 02-16-2010 11:24 AM
DIY Lighting Fixture stubits Electrical 11 10-13-2009 01:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
