Help!!!!!...........Lighting Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 04:14 PM   #1
Help!!!!!...........Lighting issues
So on saturday the lighting in my pool room went out. I have 6 overhead "cans" and then in another room there is a standard light socket. I went back to the breaker right away and it wasn't tripped. So then yesterday I looked at the cans, I have access to them, I opened up the boxes on them and looked at all the wires. Nothing looks burnt everything seems to be connected as it should be. I couldn't see anything wrong. So then today I had a chance to get to a hardware and I picked up light switches, its a 3 way. I put on a new switch on each end of the circuit. But again to no avail it still doesnt work. Any ideas? Your help would be greatly appreciated.
Trevor
tjmc25 is offline   Reply With Quote
Old 05-11-2009, 04:30 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Here is a $2 answer:
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-11-2009, 04:44 PM   #3
So with that I'd be checking if there is power running to all the boxes and lights? Sorry electrical illiterate here.
Old 05-11-2009, 05:18 PM   #4
Tool Geek
PaliBob's Avatar
Originally Posted by tjmc25 View Post
So with that I'd be checking if there is power running to all the boxes and lights?......
That's right. It's just like going to the doctor. When you describe the symptoms the Doc doesn't start writing a prescription, He pulls out his basic diagnostic tools.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-11-2009, 05:26 PM   #5
The thing that really gets me on this one is that all the outlets in the 2 rooms work. Wouldn't they be on the same circuit as the lights and switches?
Old 05-11-2009, 05:59 PM   #6
It reminds me of high school when our cars would break down and we would just start replacing parts, hoping to fix it.
You have to have a basic understanding of the circuitry in your house and you have to start tracing it down.
Read a few threads like these:
Electrical Circuit Doesn't Work
Could be a lot of reasons.
220/221 is offline   Reply With Quote
Old 05-12-2009, 07:56 AM   #7
Typically lighting and outlets are on separate circuits even in the same room. Since all of the cans are out, there's no point in testing them...start at the switches and see if you can detect voltage on any of the wires at either switch using your newly-acquired $2 diagnostic tool. Find out what else is on this circuit and test there also, all the way back to the circuit breaker itself.
It's pretty common for several rooms of ceiling lighting to be on the same circuit, something else must be out....unless these cans were added ona dedicated circuit as part of a remodel at some point.
Burbman is offline   Reply With Quote
Old 05-12-2009, 08:08 AM   #8
Licensed Pro
Loose connection or tripped GFCI would be my first guess.
Old 05-12-2009, 10:58 AM   #9
Rewards Points: 346
The OP says "I went back to the breaker right away and it wasn't tripped". Maybe it is worth mentioning that sometimes it "looks" like it is not tripped but need to be flipped off and then on to reset it. If the OP has not done that he may be on a wild goose chase.
Rege
RegeSullivan is offline   Reply With Quote
Old 05-12-2009, 12:01 PM   #10
u said the breaker didnt trip..how can you be sure..just reset the breaker
cleo19 is offline   Reply With Quote
Old 05-12-2009, 03:34 PM   #11
I have turned all of the breakers completely off. Then reset them all. That wasnt the problem. Im thinking it is an open circuit. So I was able to get my hands on a multimeter, how do I go about checking the the circuit? I read that there should be a black and white wire in there. In my box it is 2 blacks, a red and a ground. No whites at all, why would there be no whites?
Old 05-13-2009, 03:18 AM   #12
Tool Geek
PaliBob's Avatar
.... Im thinking it is an open circuit......
Good Thinking
.....I read that there should be a black and white wire in there.......
Where is In there? Is It in a Switch Box?
.....In my box it is 2 blacks, a red and a ground. No whites at all, why would there be no whites?
Again since you did not define 'In my box' I'll assume you meant a switch box.
Switch boxes may or may not have one or more 'white' wires. It depends on how the wiring of the house was originally routed.
Although it is not the original problem, since you've already changed the switches you have a good chance that one or both the 3-way switches are now miswired. That is unless you were very careful and replaced one wire at a time on the new switch so that there was no chance that any of the wires could be connected to the wrong terminal. Let us know what happens.
Be Cautious, there are > 500 deaths per year in the US from Electrocution.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-13-2009, 03:26 AM   #13
Electrical Contractor
kbsparky's Avatar
Got "juice" available at the switches?
Tags
lighting
Linking the 5amp lighting live to the 13amp neutral causes tripping of the rcb. Why? StevieV Electrical 8 08-24-2008 09:42 PM
Does All Solar Lighting in Back yard really work? KUIPORNG Landscaping & Lawn Care 11 05-27-2008 02:36 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
