Help With Light/outlet Switch Combo - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 10:41 PM   #1
Question
help with light/outlet switch combo
I connected a light switch/outlet combo in a play house. i ran it from the breaker box in my house. i had to disconnect it and know i can't figure out which wires go where. the light switch is on top and the outlet on the bottom. it doesn't have a tab that pulls off. it has a gold screw,ground screw & silver screw on one side.on the other there are two black screws with a metal tab that doesnt come off connecting the two black screws. i have the main wire from the breaker box coming into the playhouse and one wire coming from the light in the playhouse both going to the light outlet switch. both wires are remax cables have one black one white and one ground. i know the ground go together. but the way i had to hook it up before was not by placing the main black wire that goes to the breaker box to the gold screw. that didn't work. i had it going to the black screw next to the outlet. so besides the ground wires and the main black positive wire i don't know where the rest of the wires go. cam someone please tell me were the other wires go.
aftermath431 is offline   Reply With Quote
Old 07-06-2012, 12:51 AM   #2
Oso954's Avatar
Rewards Points: 1,126
black from breaker box on one of the black screws.
Black going to light on gold screw.
The whites go to the silver screw. You may have to wire nut them together with a pigtail.
Grounds to green screw.
Oso954 is offline   Reply With Quote
Old 07-06-2012, 01:04 AM   #3
Oso954's Avatar
Second thought, where is your GFCI protection ?
If you don't have it in the breaker box, you can use a switch/GFCI outlet combo.
Old 07-06-2012, 08:06 AM   #4
Rewards Points: 2,516
pulled this off another thread. In the following diagram the outlet is always HOT. The switch on the sitch/outlet combo controls the pantry light. The other switch controls the kitchen light.
here is the other thread:
wiring
help with light/outlet switch combo-switch-20combo-20with-20addtl-20switch.jpg
hammerlane is offline   Reply With Quote
Old 07-06-2012, 08:10 AM   #5
You never mentioned whether you want the outlet always HOT or switched HOT. Heres a decent youtube video on wiring up a switch/outlet combo so that the outlet is always HOT
Old 07-06-2012, 11:23 AM   #6
thanks
that you everone for the help i finally got in working.
3 way switch replacement in 1923 old house elcc1958 Electrical 3 02-06-2012 08:42 PM
Existing switch, replace with combo switch/outlet shujinko Electrical 4 04-30-2011 05:19 PM
Novice Electrician (UGH) Replacing Fan/Light combo switch jeffntonya23 Electrical 0 04-16-2011 04:42 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
combo switch problem electric1 Electrical 2 06-11-2004 10:11 AM
