Help With Kitchen Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 05:58 PM   #1
Help with kitchen circuits
I'm building new kitchen cupboards!
18 feet of counter top and I want five receptacles each on their own seperate circuits. Do I have to run five 14/2 wires to each recpt. from a 15/20 amp breaker or is there some way I can free up those breakers by putting a sub panel in my cupboard bottoms? If so what do I have to do from the panel?
rounder is offline   Reply With Quote
Old 01-24-2011, 06:23 PM   #2
WaldenL's Avatar
Rewards Points: 268
You cannot do it with 14/2. You'll need 12/2 as code requires a minimum of 2 20A circuits. I guess you could do 2 of them w/12/2 and the others with 14/2, but that seems silly, and I wouldn't swear that the code doesn't require that any circuit be 20A.
As for freeing up the breakers, you could install a subpanel, but I wouldn't do it in the cupboard bottom. Just put a sub near your original main, or in the basement under the kitchen and wire from there. Depending on the wire cost may be cheaper (or just simpler) to have the sub by the main.
BTW, why on all different circuits? Assuming other dedicated circuits for micro, DW, refrigerator and garbage disposal, how many appliances will you have on your counter. Perhaps you could just run the 2 circuits and do an A-B-A-B pattern?
WaldenL is offline   Reply With Quote
Old 01-24-2011, 06:44 PM   #3
joed's Avatar
Rewards Points: 11,588
All counter circuits need to be 20 amp. You can not put a sub panel in a cupboard.
Old 01-24-2011, 07:38 PM   #4
Rewards Points: 6,652
Posted this before, but here goes again.
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 02:17 PM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 06:05 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 09:28 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 08:13 PM
