Help With A Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 05:22 PM   #1
help with a junction box
Alright, here I am once again.
I went ahead and took out all the frayed wires out of my bathroom. There are no wires, receptacles, or switches in the bathroom.
I also removed the old j-box and installed a new steel one. I put the feeder wire in the box, secured the bx with a clamp, then secured the ends with a wire nut and e.tape (all individually). There is also another bx cable in there that is supplying power to a hall light and two receptacles. I didn't connect it the feeder because I can't tell which wire is hot and which is neutral because both wires are sheathed in cloth. Every wire has a wire nut and tape around it individually inside the j-box with a cover.
Am I good until I can call an electrician in the morning? I've had it, this stuff is making me a nervous wreck.
fortunecookies is offline   Reply With Quote
Old 01-30-2011, 06:44 PM   #2
joed's Avatar
Rewards Points: 12,854
Sounds safe until an electrician can look at it.
Junction box and light switches travesty Electrical 3 01-18-2011 01:49 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 11:03 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
