Help With Interesting Project. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 11:42 AM   #1
Help with Interesting project.
I am trying to make a movie, and I am taping at a spot in the middle of the woods. There is no electricity, and a car cannot get to this place to power my supplies. I am mainly asking for get help with one thing. I have a fog machine which I need to power. Can someone please help me figure out a way to power this for when I'm in the woods?
PoisonSamurai is offline   Reply With Quote
Old 05-05-2013, 11:50 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Car battery with an inverter that has enough output for the fog machine....what is the watt requirement of the fog machine?
Or....dry ice and water
Old 05-05-2013, 11:51 AM   #3
Licensed electrician
Rewards Points: 1,778
A small generator should fit your needs .
Old 05-05-2013, 02:56 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
A Honda EU2000 will give you about as much power as a medium to large inverter, and weighs less than a car battery alone, and MUCH less than a battery/inverter combined.
If filming in the middle of the woods is anything you are going to do, especially more than once, one of these should be standard issue.
Old 05-05-2013, 04:32 PM   #5
JOATMON
ddawg16's Avatar
I thought about generator....but....one of the issues they have is noise....unless they are going to do sound dubbing, the generator will be an issue unless you use a long extension cord.
Old 05-05-2013, 05:10 PM   #6
Have you ever "heard" an EU2000?
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
bcgfdc3 (05-07-2013), mpoulton (05-06-2013)
Old 05-05-2013, 05:21 PM   #7
Rewards Points: 166
I've worked around lots of commercial shoots and the small Honda generators are pretty standard. I presume they edit out any noise issues that arise. They need to do that for all kinds of other noise anyway.
If editing the noise is impossible then just get a long extension cord to give it some distance, and maybe put some kind of sound deadening material between the generator and the scene.
dftc is offline   Reply With Quote
Old 05-05-2013, 09:55 PM   #8
Rewards Points: 156
I was shocked the first time I "heard" one. They are an extremely quiet generator.
One of these with a 100ft extension cord should power your fog machine and not interfere with the sound unless your forest is EXTREMELY quiet. My guess is that one 4x8 sheet of that blue foam between your generator and your "scene" would completely eliminate any issues.
moondawg is offline   Reply With Quote
Tags
fog machine , power source
Drywall project: New basement bathroom NetTractorTalk Drywall & Plaster 15 10-03-2012 12:23 PM
Troubleshooting 3 switches in one box for bathroom project Jerrys84 Electrical 11 08-01-2012 02:48 PM
Foreclosure Project mike2 Project Showcase 14 05-21-2012 01:18 PM
My basement project - a 2 year project. HABSFAN2006 Project Showcase 14 07-12-2009 09:30 PM
Interesting Project Mcamnl Electrical 14 05-27-2009 01:13 PM
