Old 02-04-2010, 11:49 PM   #1
help with installing light with no ground
I have a light fixture with no ground wire I need to install in a blue plastic light box. Should I just attach white to white, black to black and ignore the ground from the power source? The fixture has no ground.
jayp is offline   Reply With Quote
Old 02-05-2010, 12:06 AM   #2
fix it
Does the fixture have a green ground screw? This is common on fixtures instead of a separate wire.
If not, and there is no screw on the fixture you can connect a ground wire from the box to, then you don't really have a choice but to ignore the ground. Unless you want to buy a new fixture. If it's in a dry location you shouldn't have any problems without the ground.
detailedEye is offline   Reply With Quote
Old 02-05-2010, 11:07 AM   #3
J. V.'s Avatar
While this technically is a violation, as detailedEye states, theres not really not any other way to connect the new fixture without pulling new cable for the circuit. So yes, I would just add the new fixture minus the ground, in my house. In your house I would run a new circuit.
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 04:36 AM
Problem Installing Track Light MrBill_DIY Electrical 5 11-12-2008 10:35 PM
Installing vanity bar light mricci59 Electrical 6 11-11-2008 02:01 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
