HELP!!! Installing A Floor Receptacle. [PHOTOS] - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 12:34 PM   #1
HELP!!! Installing a floor receptacle. [PHOTOS]
I have a huge emergency. I am getting carpet installed and JUST noticed that one of our floor outlets did not actually have an outlet in it.
I removed the "screw in plug" and discovered just wires. I have tested with the multimeter that they are live and working.
Now what? I have carpet installed tomorrow.
Is there a product that installs ABOVE the floor that I can safely use? This is on a concreate slab so I am basically screwed (can't install a traditional floor receptacle with a deep box).
Help!!! Need to do this in the next 24 hours with available parts in the Minneapolis area. Is this even possible??
This is a DIFFERENT receptacle that actually has the outlet.
This is what I am working with (sorry it's upside down):
FirstAndTen is offline   Reply With Quote
Old 03-28-2011, 02:11 PM   #2
rditz's Avatar
do these daisy chain from one to the next?? if, so, you could kill the breaker, then pull each of the floow plugs and figure out which one feeds the one with the missing plug and then cut it off so it is permanently dead.
do you use the floor plugs?? if not, why can't you kill the breaker (assume that they are the only load on the breaker), and then remove the feed from the breaker panel..
is your plan to carpet over the plugs or around them??
rod
rditz is offline   Reply With Quote
Old 03-28-2011, 02:36 PM   #3
joed's Avatar
Rewards Points: 12,356
Since I only see one wire of each color I can assume this is the last receptacle in the chain. Find the other end of the wires and cut them off. Once the wires are dead in this box you can cover it over.
The Following User Says Thank You to joed For This Useful Post:
operagost (03-29-2011)
Old 03-28-2011, 04:58 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
you know there is no requirement for them to be dead as long as they have wirenuts on them and the box is accessible, right?
In short you could just tuck those wires back in there and put the cover on, as long as you could get to it later.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-28-2011, 05:23 PM   #5
joed's Avatar
I would not consider buried under carpet to be accessible, that is why I said to disconnect it.
Old 03-29-2011, 08:50 AM   #6
Rewards Points: 590
I agree with joed's solution. If you need a receptacle here, I would recommend that you tie one end of a string onto the receptacle just before this one and the other end onto one of the wires in this empty location. When you unscrew the wire, pull it and the string all the way through to that empty hole and tie or tape the string somewhere. That way, later when you decide it's time to put a new receptacle here, (once you cut through your new carpet) you'll have a pull string.
operagost is offline   Reply With Quote
Old 03-29-2011, 09:07 AM   #7
Licensed electrician
Rewards Points: 1,462
That receptacle may be needed to satisfy the receptacle spacing rules.
Old 03-29-2011, 01:59 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
[IMG]file:///C:/Users/Bob/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/Bob/AppData/Local/Temp/moz-screenshot-1.png[/IMG]How about a tombstone electrical box. You know, like the kind on the tables in the High School Chem. lab.
http://www.lewelectric.com/images/JP.../FDN-300-A.jpg
Coastal South Carolina
Old 04-01-2011, 02:44 AM   #9
the best idea is to disconnect the wires it so dangerous even we put a carpet to it, the best thing to do is disconnect the connection of wires first befor putting some carpets.
desiree_furman is offline   Reply With Quote
Tags
in-ground receptacle
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Installing plinth blocks? Badfish740 Carpentry 6 02-09-2009 10:45 AM
Installing DWV system new construction joebart Plumbing 2 01-29-2009 07:45 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
