Help With Installating GFCI - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 12:21 AM   #16
Originally Posted by andrew79 View Post
as long as the protected outlets get fed from the load side of the gfci your good.
So what you are saying is that even if I put the line in load, and load in line. as long as the load get fed, It is still ok?
Mr.HVAC is offline   Reply With Quote
Old 07-16-2012, 12:22 AM   #17
Master Electrician
No
Your incomming power goes to line. Your devices you want protected goes to load.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-16-2012, 12:32 AM   #18
No
Thanks for the quick reply, so my question is how do I know if I wired it right?
Old 07-16-2012, 12:39 AM   #19
Master Electrician
On the back of the gfci it says line and load.
Are all three of these plugs on the same circuit? That would be a big nono. Kitchen bath and outside can't all be together. Unless your house is super old.
If you've wired it right everything will work and the gfci won't trip.
Old 07-16-2012, 12:40 AM   #20
" Euro " electrician
frenchelectrican's Avatar
Do a quick test on the GFCI receptale by pushing the test button and you should have NO power at the receptale or downstream when you " tripped " the test button.
Many new GFCI's have got better if you miswired it will not come on or reset at all. ( you will know in a second )
Merci.
Marc
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 09:29 AM
Can you test a non GFCI plug with a GFCI tester? DIYguy2000 Electrical 3 01-16-2012 07:49 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 09:24 PM
