HELP!!! Info On Changing Old Fuse Box To Circuit Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2006, 10:56 PM   #1
HELP!!! Info on changing old fuse box to circuit breaker box
We recently bought an old mobile home which had an old fuse box that is completely worn out. We would like to install a new circuit breaker box. Since there is no power leading into the home, we thought we could go ahead and install one ourselves.Question, would the power company have to run a new wire from the pole to the house if we're going to increase the wattage from 100 to 200? Or would the original power source be efficient?
BryanR is offline   Reply With Quote
Old 03-12-2006, 12:56 PM   #2
Let me do some math. 200 watts / 240 volts = 0.8 amps
I would say that a d cell battery is enough.
Or did you mean from 100 to 200 amps?
Based on what you seem to know about electricity, I would say that NO you cannot do this yourself, you need to hire it done.
jwhite is offline   Reply With Quote
Old 03-12-2006, 05:26 PM   #3
joed's Avatar
Rewards Points: 12,016
The wire from the pole to your house may or may not need to be changed. The POCO will determine that. They operate under rules than you or I. They don't go by the NEC.
You will probably need to replace all the wires form the panel through the meter can to the POCO connection point.
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 09:26 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Replacing a circuit breaker PaulGray Electrical 3 05-13-2006 10:17 PM
Circuit breaker keep retripping Gregg Electrical 4 02-18-2006 06:11 AM
