Help If It's Not Too Late!! - Electrical - Page 15 - DIY Chatroom Home Improvement Forum
Old 05-01-2008, 02:20 PM   #211
John and Silk-
It's nice to know that you guys are there if I need help. I can't really do anything until the Inspector comes out this coming Tuesday. Then we can get this party started!!! Thanks again and try not to miss me too much till then!! Cyndi
Student of the great electrical GURU.....Stubbie!
Cyndi is offline   Reply With Quote
Old 05-01-2008, 03:07 PM   #212
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Originally Posted by Cyndi View Post
John and Silk-
We'll be here Cyndi. Silk and I to help with your questions, and Joba to recommend you hire an electrician.
John
jrclen is offline   Reply With Quote
Old 05-05-2008, 10:50 AM   #213
Hey Stubbie!!! Welcome back!!! Hope you had a great time fishing.
I got the holes dug for the inspector. He'll be out tomorrow and then it should be good from then on!!
Have a great day! Cyndi
Old 05-05-2008, 04:39 PM   #214
jrclen's Avatar
Rewards Points: 514
OK, if Stubbie is back, shhhhhhh, don't tell him all that bad advice we gave you while he was gone.
John
Old 05-05-2008, 09:28 PM   #215
Power Gen/RS Engineer
Rewards Points: 566
He'll figure it out John as Cindy's gone (whoa-that rhymes). She took Joba's advice and hired an "electrician" that she met in the electrical department at Home Depot. You just can't trust that Stubbie!
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 05-05-2008, 10:12 PM   #216
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hi Cyndi
I looked at the thread early this morning for a few minutes. Then had tons of yard work to do. Anyway back from my fishing trip. We had high winds for 3 of the 4 days so only got in one full day where we could fish without getting blown off the lake after a few hours.. We caught lots of fish though the weather didn't cooperate as we thought. I may post a few pictures of some of the crappie.
I told you that the other guys here would take good care of you but I didn't think Joba Fett would show up. Anyway when the inspector finishes we can continue with the water heaters and those branch circuits that were soooooooo loooooong and see what we come up with.
I'll have to read back through the thread to see if you posted the size of water troughs your using.
Old 05-05-2008, 11:28 PM   #217
Rewards Points: 566
Originally Posted by Stubbie View Post
Hi Cyndi
Stub-
Great to have you back. Hope the fish were biting! (we all know that Joba is).
Old 05-06-2008, 10:30 AM   #218
jrclen's Avatar
Rewards Points: 514
Dang Jimmy, I was drinking coffee when I read that and almost drowned. That is funny.
John
Old 05-06-2008, 11:20 AM   #219
Why would I hire a self-proclaimed master electrician from Home Depot when I can follow the directions of a self-proclaimed expert on just about everything like Jobe Fett??????
Old 05-06-2008, 07:44 PM   #220
Joba- I don't need luck, I have real electrical experts that have offered great assistance and information here on this forum. I'm sure we will have success!! As for my girlfriend.....not sure what you are referring to. I am sure that Stubbie, Jrclen, Silk, Mr.500 and the rest of the guys don't consider themselves of the female gender. Maybe you are a little mixed up. Better get some help man.
Old 05-06-2008, 09:47 PM   #221
Hey Guys- The inspector came today and now I can proceed with the project. The excavator is going to fill in the trenches tomorrow and then Thursday thru Sunday I will be doing what I can. Thanks for all your help and I am sure that I will have a zillion questions once I get going again. You guys have been great......and a special GREAT BIG thanks to Stubbie!!!!
I will try not to bug you guys till after I get the new wiring run through the conduit.
The inspector stated that I could keep the #12 wiring if I wanted to but #10 would be an improvement for the longer runs...like you said Stubbie. I will most likely change it to #10 just in case I need to run something else off of it. In fact I may run a third circuit and terminate it there for future use. We will most likely add another animal enclosure as we expand.
Talk to you all soon. Cyndi
P.S. I told the electrical inspector, Mike that this was a great site and forum for us newbies. He might check it out. I hope he does so that he can refer others to the site.
Old 05-07-2008, 02:57 AM   #222
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Joba Fett View Post
And I do wish you and your girlfriend luck in finishing this project.
Eh.,,Buvez-vous la mauvaise bière aujourd'hui ??
Merci,Marc
[ Eh., are you drinking wrong beer today ?? ]
Old 05-07-2008, 09:42 AM   #223
jrclen's Avatar
Rewards Points: 514
Merci,Marc
l'homme est fou!
Merci, John
John
Old 05-09-2008, 11:26 AM   #224
Good Morning Guys!! I am pulling the #8 wire out this weekend and replacing with the #2 alum for the feed to the sub-panel.
Before I install the new sub-panel, I want to make sure that I replace all the necessary wire through the conduit runs.
I plan on replacing the #12 wire on the 390 foot run with #10 per Stubbies suggestion. My question is....do I replace the #12 wire that is on the shared neutral with the 390 foot wire as well?? This circuit is 170 feet from the sub-panel.
Also, by reading some of the other postings in the electrical section, I understand that I need to install a GFCI breaker (double pole..common trip) on these shared exterior circuits instead of a GFCI receptacle at each location. Is this correct??
I just want to make sure that I have a clear understanding on this aspect before I make some of the needed changes.
I have the same situation on the interior of the garage where two circuits share one neutral and I thought I could just put a GFCI outlet at the first receptacle of each circuit. If this is the case, does the same apply for the exterior outlets as well??
Thanks,, Cyndi
Old 10-02-2008, 06:28 PM   #225
5 months later
Hi All!!
It's been 5 months since I started this project and I want to thank all of you that helped me with the installation of the sub-panel and all the animal pasture lights and receptacles. Everything is working with the exception of one light fixture at one of the pastures. I can't seem to figure that one out no matter what I do.
Thanks again for all of your help. Cyndi
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 08:38 AM
Wood fence set in Cement Deck nadman Landscaping & Lawn Care 10 04-18-2008 08:59 PM
What's so hard about Bricking and Masonry? wesc Building & Construction 25 04-17-2008 04:57 PM
Late night safety concern. Please help. sooner2k1 General DIY Discussions 3 01-10-2008 09:28 AM
Holly bushes - when to trim BrianL Landscaping & Lawn Care 4 04-24-2007 03:40 PM
