Help Identifying Wire... - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 08:58 PM   #1
Rewards Points: 115
Help identifying wire...
http://imageshack.us/a/img29/4219/p1030043i.jpg
This silver wire is running down from my attic to one of the galvanized water pipes. I went up into the attic and I lose the wire to some cramped parts of the house. It doesn't appear to run back to the electrical box. Any ideas what this could be? A ground wire? I am repiping with Pex....do I need to extend this wire to another part of metal, or can it simply be removed?
Thanks for the advice.
Didymus21 is offline   Reply With Quote
Old 09-30-2012, 09:05 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Cable or telco ground. Most likely telco.
Yes, you should route it to a valid grounding source.
Old 09-30-2012, 09:08 PM   #3
Rewards Points: 115
Thanks! Is it likely aluminum wire? Want to buy a like type if I'm going to extend it....
I'm assuming I can't just mix copper grounding wire with this.
Old 09-30-2012, 09:11 PM   #4
Highly unlikely that it is AL, although it looks like it. Good chance it is tinned CU. How old is it (the wire or the house)?
You are right, do not mix CU and AL in a splice, or if you do make sure you get an approved splice for it.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Didymus21 (09-30-2012)
Old 09-30-2012, 09:13 PM   #5
Rewards Points: 115
House is 74'. You're right it is tinned CU when I looked at a cross section. Is it imperative this is grounded immediately? I'd like to remove some of this pipe tonight but won't be able to get more wire tonight.
I don't suppose the fact that I don't have phone service at the house doesn't make a difference does it?
Old 09-30-2012, 10:01 PM   #6
Electrical Contractor
kbsparky's Avatar
Some older houses used to ground their bathroom fixtures by running a single conductor from the bathroom light(s) to the water pipes.
Betcha this is one of those deals
-KB
Old 09-30-2012, 10:21 PM   #7
Rewards Points: 115
The wire does not lead to the bathroom light or fan. Bypasses them and appears to head toward the kitchen area. There is a phone line over there....
Old 09-30-2012, 10:28 PM   #8
kbsparky's Avatar
They installed similar grounding schemes in kitchens as well ....
-KB
Old 09-30-2012, 10:33 PM   #9
Rewards Points: 115
I can see that. But, if it were for the kitchen it seems like they'd just connect to the galvanized in the kitchen. Instead, this runs a good 30 ft in the attic then through the wall to galvanized in the bathroom.
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
