Help!! I Want To Be Sure My House Doesn't Burn - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 12:11 AM   #1
help!! I want to be sure my house doesn't burn
When I turned off our basement light earlier, I swear I saw a flash of light behind the panel ( in the wall). I just passed it off as nothing. Now when I go to turn off the light switch, it felt pretty damn hot. now I am scared to go to sleep, as I hae a 4 and 8 year old in the house. The longer I have left the switch off, the cooler it gets .. however, I am still worried .. anyone w/ any ideas??!!
LAKECREEK is offline   Reply With Quote
Old 01-27-2009, 12:14 AM   #2
Rewards Points: 150
When you say panel do you mean the main electrical panel or the switch cover plate?
Steelhead is offline   Reply With Quote
Old 01-27-2009, 12:15 AM   #3
switch cover plate
Old 01-27-2009, 12:24 AM   #4
Rewards Points: 150
Switches do arc somewhat when turned on and off.....but a hot feeling switch.....if you have no electrical knowledge at all or any testing equipment, if it is possible, I would turn on the light (so you know you have the right breaker) and then find and turn off the breaker until someone with more experience can take a look at this for you.
Old 01-27-2009, 12:28 AM   #5
done deal!!! thank you for the help!!!!! have a great night!!!
Old 01-27-2009, 12:33 AM   #6
Rewards Points: 150
You too. Be safe.
Old 01-27-2009, 07:37 AM   #7
It sounds like the switch is wearing out. When they wear out, the contacts inside may not make a good connection, and could heat up.
I would replace the switch ASAP.
thegonagle is offline   Reply With Quote
Old 01-27-2009, 07:44 AM   #8
Whatamess
If you found the correct breaker and it killed the power to the light you can replace the switch your self.
If there is more than two wires draw a diagram of how they hook up. If you control the light from two different locations you will need a 3way switch.
It is an easy task if the power is off.
Good luck
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 01-28-2009, 11:15 AM   #9
Rewards Points: 240
Kill power. Replace switch. Drink two beers. Done. Sleep!
Old 01-28-2009, 11:29 AM   #10
Maybe it's just that the screw terminals are loose.
A good switch dissipates less than 1/2W at 15A; you wouldn't notice this temp. rise. Yours might be cooking itself with a few watts.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
