Help! I Broke My Main Disconnect Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 04:28 PM   #1
Talking
Help! I broke my main disconnect breaker
I shut the power off to the house at the main disc panel which houses only the main disc breaker, a westinghouse 200a (probably very old), to wire a sub panel off the main panel. When I finished the work, I switched the main disc breaker back on and it went mushy. No firm click on or off at this point. Where can I get a replacement breaker, as I don't have any power to the house at this time. Much Thanks, Steve
kosherdill is offline   Reply With Quote
Old 01-31-2009, 04:52 PM   #2
Res Ipsa Loquitur
Can't say where to get that particular breaker (an electrical supply house would be my first guess) but even if you could replace this the power to the MAIN box must be disconnected (the meter would need to be pulled by POCO or electrician). Replacing the main is not a DIY project. If it is as old as you think you might want to consider a new panel altogether which would include a new 200a breaker.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-31-2009, 04:53 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,078
Ayuh,...
You need an Electrician,+ also contact the Power Co. to turn the feed off....
The Electrician will know where to get the replacement breaker...
Old 01-31-2009, 05:01 PM   #4
thanks for the info
I was coming to the same conclusion. My DIY mentality was trying to find a way to fix it myself on a Saturday evening, but as you both said, this one's best left to a pro. Thanks again...
Old 01-31-2009, 05:06 PM   #5
Have you tried turning it off then back on?
I have heard some will turn back on
Old 01-31-2009, 06:25 PM   #6
Rewards Points: 876
Make sure you didn't mis-wire your sub, and the MAIN is just tripping out on you when you try to reset it!
FW
Ultrarunner2017 is offline   Reply With Quote
Old 01-31-2009, 11:58 PM   #7
I hate when that happens
Usually I can get it to turn back on with a combination of brute force and gentle finesse. Once or twice....not. That's why I keep a stock of old breakers stripped from service changes.
220/221 is offline   Reply With Quote
Old 02-01-2009, 08:23 AM   #8
Its definitely broke
I tried the gentle on/off. An electrician I called suggested a couple of forceful, yet light taps with a wooden or non metallic handle on the sides of breaker to get spring? or whatevers inside a breaker to engage or reset. Still no joy. Lastly, the backup generator comes on no problem, with no sign of overload or other deviations. Thanks for the hints and help again. The electrician is coming over this afternoon to asses breaker replacement or panel replacement.
Bad main breaker? jm8891 Electrical 13 11-09-2013 09:32 AM
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 04:40 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
Main disconnect breaker coyote556 Electrical 9 08-01-2007 04:52 AM
