I got a cage blower and motor from a heating and cooling place and I want to make an air cleaner for my shop. I would like the advice of a pro before I dive in and fry this motor. I"m guessing blower white wire goes to house white neutral wire. Ground the motor and blower assembly with bare wire from house wiring. Put a four way selector or four way with an off position for the different speeds and connect to the black common house wire. Put the on off switch on the common black house wire? What kind of selector would you recommend? Do I need to add airflow resistance to this blower so the motor doesn't draw too many amps? This blower no longer has the resistance of a house full of ducting. Has anyone ever tried this and what were your experiences?
Thanks,
John
General Electric 1/2 hp 115v 7.9amp 1075rpm
part number 5KCP39LG
Thanks,
John
