HELP!!! How Do I Wire Up My New Light Fitting??? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 02:08 PM   #1
Question
HELP!!! how do i wire up my new light fitting???
SOMEBODY HELP!!! i have taken down an old light fitting and stupidly didnt take notice of the wires and am now faced with a huge problem i have 4 core wires each with a LIVE , NEUTRAL , EARTH how do i wire them into my new light fitting??? i have enclosed a diagram drawn representing my problem. HOPE SOMEONE CAN HELP ME
THANKS X X
starbabe78 is offline   Reply With Quote
Old 09-29-2010, 03:11 PM   #2
Not enough information to answer your question. Most likely scenario is that one is the supply from the panel, one or two are switch loops, and one or two are feeds to outlets or other lights. Wire tracing or at least a continuity test will be needed to tell which is which.
hayewe farm is offline   Reply With Quote
The Following User Says Thank You to hayewe farm For This Useful Post:
starbabe78 (09-29-2010)
Old 09-29-2010, 05:52 PM   #3
all i know is that all them wires work all the lights upstairs so at present i'm walking around in the dark ( luckily i ate me carrots wen i was younger lol) they were all connected to my old 3 spot light fitting which i had on the landing which has a 2 way switch (operated from upstairs or downstairs) but also connected was a EARTH wire to a terminal block and also a NEUTRAL wire to a terminal block and i also removed a spare terminal block that had wires in but cant remember which wires!!
dunno if this extra info is any help.
thanks
Old 09-29-2010, 06:01 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
You should also mention that you are not in the US, and maybe let us know where you are.
The Following User Says Thank You to Speedy Petey For This Useful Post:
starbabe78 (09-30-2010)
Old 09-29-2010, 08:08 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Once you tell us what location you are in due the way you describie it kinda toss up between UK and Aussie so if can you confirm it ?
Once I know which one then I can able tell the correct way to do this.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 09-30-2010, 03:17 AM   #6
hiya thanks 4 ur replies i am in the uk
Old 09-30-2010, 06:31 AM   #7
ahh eventually i've managed to solve problem took a look at other light fittings around house and found one identical altho i did not know which one was the live wire as it had no sheath around it but took a wild guess at it being the one that had the wire folded over and HEY PRESTO all my lights are working i'll remeber to take note of what wires go where next time i remove a fitment.
HELP - wiring a 4 gang switch panel Tim_ Electrical 31 01-14-2010 05:27 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 06:29 AM
What is the est way to wire up a switch and light.... jailbird371 Electrical 5 05-30-2009 08:24 PM
Stobe light ground wire getting hot! kaliyg Electrical 3 08-21-2008 09:27 PM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 07:03 AM
