Help! - How Do I Wire A Polarised USA Plug?? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2003, 05:15 PM   #1
Guest
Guest
Posts: n/a
help! - how do I wire a polarised USA plug??
Urgent - please help
which side does the live wire go to? - the fatter or thinner prong?
thanks
Old 12-22-2003, 06:27 PM   #2
Guest
Guest
Posts: n/a
The hot wire goes to the brass colored screw, which should be the smaller opening.
Old 01-04-2010, 09:11 PM   #3
Master Electrician
richgriffith's Avatar
The wide prong on the plug should go to the base of the light bulb. The narrow prong on the plug should go to the dot at the center of the socket. The wide prong is neutral/return. The narrow prong is the hot side.To add some more detail, the wide prong (the neutral) connects to the ribbed lamp-cord wire. The rib denotes the 'white' wire (neutral). Then the ribbed wire goes to the silver (nickel) colored screw on the lamp-holder. The non-ribbed side of the lamp-cord, is obviously then the 'black' (hot) wire. It connects to the gold (brass) colored screw on the lamp holder. The old electrician's adage is at play here:
'Black to brass; or burn your as$'.
hope this helps not sure what your wiring.
richgriffith is offline   Reply With Quote
Old 01-05-2010, 10:13 AM   #4
For a light?
Billy_Bob is offline   Reply With Quote
Old 01-05-2010, 12:16 PM   #5
Thumbs up
Presuming that the (house) wiring is correct. BTW; As was discussed on another thread on this Blog, the regionality? (Geographic location) of this poster can be discerned (by the Spelling, and the inquiry) not to be from the USA and Canada!
spark plug is offline   Reply With Quote
Old 01-05-2010, 12:20 PM   #6
Thumbs up
Billy Bob (Poster #4) The sketch is great but it has one incorrect detail; It shows the NEUTRAL wire (on the Socket base) threaded the wrong way. (Counterclockwise) ! (No matter what) Don't Drink and Drive, Ever!!!!
Old 01-05-2010, 01:21 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
You guys know that this is a 6+ year old thread right.
If the op has not figured how to do it, it may never get done.
jbfan is online now   Reply With Quote
Old 01-05-2010, 07:53 PM   #8
Thumbs up
You're right. We (actually, I'm speaking for myself only!) like to shoot first and ask questions (or provide answers) later! But, It DOES have some relevance for today. On another thread in this Blog, there was a discussion about requiring posters to identify their region or country of residence. Because different terms and pronunciation were used in the various places. Someone pointed out that by the form of inquiry and Spelling we can identify which (English-speaking) country they hail from. For example, in the thread under discussion we know for sure that the inquirer does not live in Canada, or the USA. Because the Canadian Electrical system, (today) is identical to that of the USA. And by the form of Spelling, it could be Australia-N.Z. or the UK. !
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
