Help, How Dangerous Is This Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 09:32 PM   #1
help, how dangerous is this wiring?
during our recent roof replacement while I was walking and looking down from the top I spotted this wiring connection seen in the pic that is outside a box and with a transformer hung from a wire in the attic, how dangerous is this? It's in a hard to get place up there, looks like a broken up box is laying down below it. I imagine it is the thermostat connection for climate controls? Not sure how long it's been like that. should I be calling an electrician over right away to get it into a box?
kneejerk is offline   Reply With Quote
Old 06-15-2012, 09:41 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Just install a new metal box... Its not an emergency call, but something that needs to be addressed... put a list together if you can to save a trip out for the guy.
Old 06-15-2012, 10:58 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,902
That mess definitely needs cleaned up. It's not a super emergency, but it isn't good either. I can't tell if the tan wire to the right of the transformer is connected to the 120V line. If so, that's bad. Also, there appear to be two black wires coming out of the broken box. Not sure what for but it's not normal. There's probably more badness elsewhere in the house too. These things rarely exist in isolation.
mpoulton is offline   Reply With Quote
Old 06-16-2012, 10:02 AM   #4
Household Handyman
Rewards Points: 1,408
This appears to be a bell transformer for the doorbell(s). The grey/blue box lying on the insulation appears to be an old transformer that was replaced by the newer shiny one. Where the wires from the newer transformer (110vAC in/12vDC out) are tied into the electrical circuit with the wire nuts, this need to be in a junction box with a cover plate on it. Actually IMO the transformer should be secured onto the top of a ceiling joist.
The Following User Says Thank You to Thurman For This Useful Post:
DangerMouse (06-16-2012)
Old 06-16-2012, 05:24 PM   #5
"how dangerous is this wiring?"
Well, what all can go wrong and how will it go wrong and how long will it take to go wrong? This is best answered by experienced electricians.
The wirenuts are not in a fire-resistant box but the transformer hardly draws any current so they won't get hot from bad connections unless the 'frmr shorts.
Somebody mucking around up there can maybe kick the wires out of the wirenuts and so you'd have 120v exposed but there is no water or grounded metal surfaces nearby. If they spark I guess they could ignite something and you may not smell smoke from this fire.
The loose cable can trip someone.
The transformer may overheat if it is not surrounded by free air.
Rodents can chew the wires but that is true of any hookup.
Other?
Old 06-16-2012, 07:03 PM   #6
Other?
Thanks, this is the kind of "what if's" I was thinking about. My main concern was the transformer shorting out and maybe causing current draw enough to start a small fire before the breaker kicks (if it's on one!). The other concern I had is the transformer falling down from the wire it's hung from and similar over heating occuring. Nobody is going to trip on it as it is a portion of the attic that is not accessible, further complicating a repair attempt (I think).
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 11:00 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
