Help With Grounding Rod Requirements Please - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 01:19 PM   #1
Rewards Points: 33
Help with Grounding Rod Requirements Please
I recently purchased a home (Wisconsin) built in 1979. After removing some vegetation, I found a serious flaw in the service grounding. There is one grounding rod driven in near the service entrance. It wiggles like an 8-foot rod shouldn't and the ground cable was loosely wrapped around it... not connected with a proper grounding clamp.
I am doing some cement pouring back there in a few days and want to rectify this situation. Does the following "work" to code?:
2 8-foot grounding rods... at least 6 feet apart... connected to the panel with one cable... both buried under my new concrete slab.
Thanks for any help!
Koellert is offline   Reply With Quote
Old 10-07-2013, 01:32 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The connections to the rods must remain accessible, so you will not be able to pour over them.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Koellert (10-07-2013), plummen (10-08-2013)
Old 10-07-2013, 01:54 PM   #3
Rewards Points: 33
So, other than burying them under the cement, everything else should be "legit?" What gauge wire has to be used?
Old 10-07-2013, 01:56 PM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Wouldn't the 250.68(A) exception #1 apply here?
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
Old 10-07-2013, 02:39 PM   #5
i would think so. classic nec...keep it exposed but if you bury it then you don't have to.
itsnotrequired is offline   Reply With Quote
The Following User Says Thank You to itsnotrequired For This Useful Post:
Msradell (10-07-2013)
Old 10-07-2013, 02:53 PM   #6
Rewards Points: 510
Old 10-07-2013, 03:04 PM   #7
Rewards Points: 510
I would go with a #6 copper.
Old 10-07-2013, 08:23 PM   #8
Rewards Points: 774
The 6' is a minimum (as you noted) the further apart the better.
Know A Little is offline   Reply With Quote
The Following User Says Thank You to Know A Little For This Useful Post:
Philly Master (10-08-2013)
Old 10-08-2013, 05:37 AM   #9
Philly Master's Avatar
Rewards Points: 516
do you have a copper pipe coming in from the street ????
that is the more important one if you do ...is there a copper wire running from there to the panel ???
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Old 10-08-2013, 06:03 AM   #10
Electrician
Rewards Points: 150
... I am doing some cement pouring back there in a few days and want to rectify this situation. ...new concrete slab. ...
Is there at least 20 feet of rebar encased by at least 2 inches of concrete? That would be a superior ground to rods. It's called a CEE or Concrete Encased Electrode (NEC '08 250.52(A)(3)).
Alternately, 20 feet of #4 AWG bare copper wire encased under 2 inches of concrete, with enough extra wire to reach into your box, is also to code.(ibid.)
Glennsparky is offline   Reply With Quote
Old 10-08-2013, 07:45 AM   #11
for an existing home, this isn't very practical. for new construction, exposed rebar MUST be bonded to the grounding electrode system (provided it is minimum 1/2" diameter and totals 20' in tied-together-length). of course, once the rebar is covered, it no longer needs to be connected.
Re-use a service entrance cable and grounding requirements CapeCod153 Electrical 22 05-06-2013 08:58 AM
2-2-4 SEU - Smaller Neutral? BRT Electrical 18 09-23-2012 10:25 PM
Panel Grounding requirements POWER STROKE Electrical 3 08-27-2012 06:46 PM
Earth Grounding Rod Requirements wewantutopia Electrical 31 08-26-2012 07:38 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
