Help With Grounding Bar On New 200a Main - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 04:17 PM   #1
help with grounding bar on new 200a main
I am replacing my 200 amp 20 space panel with a 200 amp 40 space panel. I am replacing the panel rather than installing a sub panel. I am confused on how to wire the ground bus bar. my current panel has 2 separate neutral bars that are used for both neutral and ground and are connected to each other. The new panel box also has 2 separate and connected neutral bars. I want install a separate ground bus bar to make things a little neater. Do I need to connect the neutral bars to the ground bar and/or to the connecting strap to the metal box?
djasinski is offline   Reply With Quote
Old 07-24-2012, 04:24 PM   #2
Rewards Points: 1,452
The two neutral busses (bars) need to be bonded to each other using the approved strap.
(Assuming that this new 200 amp panel is the main panel, its breaker is the first main disconnect for the building)
Provided that there is good bare metal to metal contact between the ground bus bar and the panel back and good bare metal to metal contact between the strap or other metal contact for the neutral busses and the panel back then you don't need a direct connection between the neutral busses and the new ground bus.
Old 07-24-2012, 04:29 PM   #3
So, you say that I do need to bond the neutral and ground bars somehow, either direct strap bond or indectly through the back panel?
Would this change if I wanted to conect a generator via interlock kit and 30a breaker backfeed?
Old 07-24-2012, 09:50 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I have never seen a 200A 20 space panel. I'm not saying that they haven't ever made it, just that I've never seen it.
electric grounding bar in main panel steve gregory Electrical 13 01-22-2012 03:20 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Grounding Questions ZBat910 Electrical 61 09-09-2011 03:45 PM
Main grounding electrode wire to panel rovers1973 Electrical 4 03-18-2010 07:18 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
