Help! Glowing Spot At Bonding Screw - Electrical - Page 6 - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 07:49 AM   #76
Unbelievable. I've never read anything like this before. The Detroit PoCo is a disgrace to the industry. Keep the kids out of the basement as long as your plumbing is energized....
kwilcox is offline   Reply With Quote
Old 12-10-2011, 09:47 PM   #77
liscenced electrician
Rewards Points: 538
Our power company would be out same day. No question about it
jimmy21 is offline   Reply With Quote
Old 12-12-2011, 11:52 AM   #78
I ask the impossible!
Rewards Points: 692
Hehe... well, that's easy since we don't have a basement. The house is over a dirt crawlspace and has been standing since 1917 without a foundation.
So today, I went to work, then came home to see if I could work from home and keep an eye out to make sure the job got done right. When I got here, there were 4 trucks out in the street and the new service drop was already finished, they were just wrapping up some tree trimming.
I shut off my main and pulled my jumper wire to verify that the open neutral had been cured, and it had. So I put the jumper back to keep everything safe, looked outside to make sure I had proper garage clearance and that was good.
So ultimately, it seems I finally got the right people out to make the PoCo's part of the system right.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 12-14-2011, 06:47 PM   #79
Rewards Points: 83
Been following your situation. Glad DTE finally got it sorted out. I see from your experience and other's comments that DTE is as bad as my experience with them.
They let a 50,000 volt line keep my back yard on fire for 72 hours this summer, no exxagerating. (I'm not sure I have the exact voltage correct, but the order of magnitude is correct. It was a subdivision primary transmission line. And they knew this.)
You might remember a horrendous storm in early July this year. One of my neighbor's trees came down, snapping one of the primary transmission lines that runs along our back yard. I never got them to tell me precisely how much voltage it runs, but they confirmed it was tens of thousands of volts, and researching online it looks like those are usually 50kV. One end fell into our back yard, dangling on the fence, trees, and shrubbery. We were going outside to check the house for storm damage, and I heard that horrible electrical arcing sound.
DTE's emergency line was only accepting automated calls, so called 911. Within a few minutes, the arcing quickly set the shrubbery on fire, despite everything being soaking wet from all the rain.
The fire department came out, and an hour later said their dispatcher was still on hold trying to get in touch with a person at DTE, about my fire and two others in Westland due to downed wires. Apparently DTE has an unlisted phone number for city dispatchers to be able to call - this way, the city dispatcher can sit on hold for a longggg time to speak to someone, but it at least doesn't say they're only accepting automated calls and hang up on the person. They gave me this number, and said I could try calling them too.
I'm a squeeky wheel, so I was calling the DTE city emergency line every 1-2 hours, after my last conversation with them. That night, hold times were over an hour each. They kept saying for 72 hours they couldn't give an ETA to get the line shut off.
Each time I spoke with them, I asked for a supervisor. I explained I knew a lot of people were without power, and I wasn't asking to have my power back -- I just wanted the line turned off. I explained that my backyard was on fire. I explained that it was dangling on a metal fence, and that everyone has metal fences linked together in my neighborhood, so there was an electricution hazard even like 10-20 houses away.
No line crews showed up, but a few DTE workers who weren't line workers came by to see the fire, and verify that the situation was really bad.
DTE supervisors kept blaming it on dispatch, saying they were sending in escalated priority tickets, but that dispatch kept sending out non-line workers and ignoring the tickets.
Fire department finally left about 6 hours into the fire, saying they couldn't sit there the whole time that it burned. They of course can't use water to fight it, and said all they could do is spray foam on our house if it got significantly closer to the house. Luckily the fire never got closer than 8-10 feet.
Fire department told us to watch the fire, and call back if it got closer to the house. So, my wife and I got to take shifts watching the line for 72 hours making sure the house didn't burn down, while frantically making phone calls to supervisors at DTE begging to just have the line shut off.
All this, while DTE was busy at work in my subdivision getting the rest of the neighborhood's power back on. I'd even drive by DTE trucks, begging them to shut it off, and they all said they had to follow the tickets in order given by dispatch, while they saw smoke off in the distance. The head line crewman that eventually came by said quite a few things about DTE that I can't repeat. He was very upset about the non-important jobs they had been having him do for the past few days when this was still going on.
Here's a link to a video I shot when it had just about started. It got much worse, but I didn't shoot any additional video.
darlingm is offline   Reply With Quote
Old 12-14-2011, 07:05 PM   #80
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
All I can say is WOW!
I glad all you had was a fire and no one got hurt!
Old 12-15-2011, 12:19 AM   #81
Semi-Pro Electro-Geek
Rewards Points: 2,938
That's unbelievable! I can't imagine that a situation like that could occur in the United States. That line was almost certainly 7200V, not higher - but an incredible hazard nonetheless.
mpoulton is offline   Reply With Quote
Old 12-15-2011, 07:12 AM   #82
Rewards Points: 1,512
A single 7200 volt primary is one line of a 12,500 volt 3 phase primary system. It is not unheard of for the primary system to be in the 30 to 50 KV range phase to phase in which case the single primary would be around 17,000 to 29,000 volts phase to ground.
If the pole top insulator for the primary suggests a pine cone rather than a mushroom then there is a good chance that the phase to ground voltage is over 15 KV.
Old 12-15-2011, 10:10 AM   #83
Rewards Points: 83
Picture came out pretty bad through a window, but gets the job done. Looks to be a pinecone style to me.
Almost all of the rest of our neighborhood got power back before the line was shut off. Strangely, to me anyway not having a great understanding of the grid, they got everyone else power except for one neighbor on one side, and two neighbors on the other side, with that line in that condition.
Old 12-15-2011, 04:37 PM   #84
Rewards Points: 38
that is totally unbelievable. around here we ran 13.8 kv. 7.2 near the salt h2o. the closest thing i ever saw was an arc on a 3 ph pole in a driving rain. the trouble man could not open the switch from the ground, so he went up in the bucket w a sledge hammer. I was inside watching. it was lighting up the sky.
i think dept public utilities needs to see that video.
bernie963 is offline   Reply With Quote
Old 12-15-2011, 06:29 PM   #85
kbsparky's Avatar
That size insulators could possible handle up to 14,400/25,000 Volts. But probably not 50,000.
Most neighborhood distribution systems operate at 7200/12,500 Volts.
-KB
Old 12-16-2011, 08:22 AM   #86
Rewards Points: 692
File a complaint with the Michigan Public Service Commission, it's the state regulatory agency responsible for holding public utility companies accountable to customers.
http://www.michigan.gov/mpsc/0,1607,...415---,00.html
Robertson tip stuck in screw djgrant General DIY Discussions 4 07-05-2011 04:18 PM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
gas line vs screw wobblybowl Plumbing 5 05-27-2009 10:49 PM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 06:38 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
