Help Fixing Garage Electric For Home Theater - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 11:27 AM   #16
The conductor for #10 AWG is 3/32" in dia.
Old 05-12-2010, 11:48 AM   #17
Rewards Points: 1,512
If you don't have a third insulated wire (usually red) in the cable coming into the subpanel from the house, then it's not a 10-3 cable and there is no further need to look at the cable jacket for a label.
With just black, white, and bare you must remove the white from a breaker post back at the main panel and connect it to the neutral bus there in order to have 115 volts at the subpanel using the existing cable. You will now have only one allotment of 30 amps at 115 volts.
Others would disagree with me but I would string overhead conductors (four: hot, hot, neutral, ground) from house to garage before I dig up a nice concrete or asphalt driveway in between for an underground feed.
If you string a new feed from the house to the garage, you must decommission the old feed including if one is overhead and the other is underground. So the new feed should be be heavy enough to handle all of the loads. Only one feed of any given kind can go between any two buildings. (115 or 115/230 volt feeds are considered the same kind; a 3 phase feed, rare in residential areas, is a different kind) You could install a new subpanel and connect the existing subpanel as a sub-subpanel.
Old 05-13-2010, 09:56 AM   #18
Rewards Points: 160
You can only have a 120 or a 230 volt circuit with this cable, not both. No 120/230.
120 Volt - Wht - Neutral, blk - Hot, Bare - Ground.
230 Volt - Wht - Hot, Blk - Hot, Bare Ground. No neutral present.
If it were my house, I would install a 100 amp sub. Since you have to do all this work, why not do it right this time and be done with it. That's just me.
Don't forget! 4 wires!
Fixing a Flooding Garage Earthworm Jim General DIY Discussions 4 05-03-2010 08:20 AM
installing electric heat garage - frozen pipes? mothgraphics Electrical 10 12-20-2009 12:29 PM
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 08:58 AM
Electric in garage kelr Building & Construction 3 04-15-2005 07:50 PM
electric service in garage kelr Electrical 2 03-26-2005 08:38 PM
