Help. Finding Single Gang Ceiling Fan Light/fan Switch With Remote - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 01:17 AM   #1
Rewards Points: 224
Help. Finding single gang ceiling fan light/fan switch with remote
Probably an idiotic question but hopefully someone knows the current market. I really would prefer something that has the fan and light control in a single gang and has a separate remote. I think there is something by hunter where the remote mounts in the switch plate but that is not ideal.
I am not too concerned if this is a PWM controller or a simple rheostat.
viper is offline   Reply With Quote
Old 08-30-2010, 05:48 AM   #2
AFAIK, you either use a wall-switch controller (dual slider) or you simply install a regular wall switch and use a remote-control adaptor and wire that into the canopy if you need remote control. I do not think you can get both.
LawnGuyLandSparky is offline   Reply With Quote
Old 08-30-2010, 09:19 AM   #3
I don't know if I understand your question but there are fan/light combos out there that use just a single gang switch for both fan and light control. They usually also are remote capable. Most remote capable fan/lights that I have seen use just 2 wires from the wall switch box to the ceiling box.
slipgate is offline   Reply With Quote
Old 08-30-2010, 05:09 PM   #4
Master Electrician
Rewards Points: 3,678
I am sure this option is available on Minka brand ceiling fans.
brric is offline   Reply With Quote
Old 08-30-2010, 06:54 PM   #5
Electrical Contractor
kbsparky's Avatar
Available at Lowes. Item 179384:
-KB
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 11:10 AM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
