Help With Electrical Service Hookup Near Meter! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2009, 07:10 AM   #1
Rewards Points: 156
Help with electrical service hookup near meter!
I've been renovating an old house and had removed aluminum siding from the entire house except for this final area near where the main service comes in from the power pole and the drip loops attach to the house. First of all, I've never really liked the way this looks but such is life. I would like to at least temporarily detach all of this for long enough to remove the aluminum. Do I need to get the power company to disconnect me while I do this?
jayp is offline   Reply With Quote
Old 03-25-2009, 08:09 AM   #2
you,....yes....me,...no....technically, i think everyone is supposed to get the utility involved, i guess each state or county, or parish differs....but, you as the homeowner, i would get a licensed electrician to just file the job and move it.....and tell him to get rid of that se...
NolaTigaBait is offline   Reply With Quote
Old 03-25-2009, 08:11 AM   #3
Yeah, those SE are unfused, means that its always live. Only the power company should work with it without someone getting hurt or killed.
What they would most likely do it disconnect the line at the pole and then at the house.
You should consider a new SE anyways.
rgsgww is offline   Reply With Quote
Old 03-25-2009, 08:26 AM   #4
Rewards Points: 156
school me
Ok, I'm no electrician so feel free to school me here. What do you mean by SE? I had a jackball of an electrician upgrade my service a few years ago before I knew better and his work was less than stellar.
Old 03-25-2009, 08:31 AM   #5
theres nothing wrong with it....i woulddn't use it though...its legal....se, is a flexible cable used for service entrances, like what you have...
Old 03-25-2009, 09:22 AM   #6
Rewards Points: 156
ok
YOu're talking about the big cable running down the house? Yeah, I hate that thing too. I was thinking about cutting a piece of pipe in half with the table saw to cover it up.
Old 03-25-2009, 09:35 AM   #7
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
How would you remove thid with it disconnected at the pole? Just cut and cap up at the but splices or would you cut it at the pole yourself?
To the OP call the power co for a temp disc, they will cut it at the pole.
jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-25-2009, 11:05 AM   #8
Why not have the SE cable replaced with conduit and a weatherhead, not really expensive.
Old 03-25-2009, 02:33 PM   #9
jamie
yes, i would call an electrician , he will file the permits and call the utility for a cutin/ cutout...me, if i were not to file it...i would just cut the drop, install a strain relief clamp(which there is no on this drop), and temporarily secure the drop somewhere else while he removes the siding, once he fixes the siding , install an insulator and reconnect the drop...its not that big of a deal, electricians do it all the time
Old 03-25-2009, 03:01 PM   #10
Some pocos allow electricians to do as nolatigabait just said.
Old 03-25-2009, 05:20 PM   #11
Good God that is ugly and unsafe. I don't care if it is legal, it is not a good way to install unfused cable. Stapled to wood siding with metal clamps?
Seems like the wind blowing could cause the wires to move back and forth over the years and cut the strap thru the cable.
Call power company to disconnct while you reside it. Make sure that point of attachment is securly thru bolted thru the framing and re install the cable.
That is dangerously ugly.
220/221 is offline   Reply With Quote
Old 03-25-2009, 10:32 PM   #12
Union Electrician
goose134's Avatar
I'm going to admit that I didn't have my cheaters on and I simply thought the service entrance was rigid bent in the fork of a tree. I was sadly mistaken. Rip it out.
goose134 is offline   Reply With Quote
Old 03-25-2009, 11:05 PM   #13
Rewards Points: 150
I had the service cut by the poco during a siding job, didn't cost anything.... they took the wire and all (it was old)
I put up a new through-soffit, rigid mast, new square D box, looks nice.
poco wouldn't reconnect service until I got new box/mast inspected. Then they charged me a $200 reconnect fee
johnnyboy is offline   Reply With Quote
Two units on property using one electrical meter WRT54G Electrical 6 02-03-2009 08:53 AM
electrical service for new house ehurlbut Electrical 4 08-20-2008 08:14 PM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 07:35 PM
meter to service panel mikim Electrical 5 05-04-2007 05:34 AM
electrical service to barn bsteven Electrical 1 04-18-2005 08:43 PM
