Help Electrical Panel Overload - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 07:31 PM   #1
I have an Thomas&Betts model TBB10 (20-20)c electrical panel. My question is I still have room for more breakers but all the neutral and ground wires take up all the buss space. In this panel which I did not install, they already have some ground and neutral wires under one screw. They do not have them mixed but some have two ground and some have two neutrals. My question is I need to add another breaker ( I have 3 open spots) but I have no place to put the neutral or ground.
hrdrok is offline   Reply With Quote
Old 02-10-2011, 08:49 PM   #2
Rewards Points: 1,548
You can buy another buss bar (terminal strip) that you can mount in a less crowded spot in the panel.
Old 02-10-2011, 09:00 PM   #3
I bought a ten screw buss at Lowes, but did not know if I can just screw that to the panel. They other 2 buss have grounds wire. Right side buss has a ground wire to the main water line and the left side buss has the 3rd wire from the incoming service. Would I put ground or neutral wires on the new buss?
Old 02-10-2011, 10:19 PM   #4
Journeyman Wireman
Rewards Points: 150
If you are only adding one breaker, free up lug space by pigtailing some of the grounds together and putting the tail in one lug. Just size the ground pigtail to the largest of the grounds your are combining. If you want room future circuits, add an additional ground bar.
Jupe Blue is offline   Reply With Quote
Old 02-11-2011, 07:19 AM   #5
...Just size the ground pigtail to the largest of the grounds your are combining ...
Regarding a bus bar purchased separately, if you put only 12 (and/or) 14 gauge ground wires and no neutrals on it, then just one 12 gauge wire goes from it to the bus bar already on the panel.
Depending on the separate bus bar and the instructions, it might not be necessary to run any jumper from it to the bus already on the panel.
Electrical Panel Knockout Help atw58 Electrical 15 05-04-2016 05:54 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Recessed Light & Electrical Panel MartinD Electrical 3 09-30-2010 07:42 PM
Upgrading an electrical panel syndicate1 Electrical 6 07-05-2010 10:35 PM
