Help Drilling Hol Through Thick Top Plate For Conduit. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 08:26 AM   #1
Help drilling hol through thick top plate for conduit.
Been trying to drill through that top plate for my 2 inch conduit. For some reason, it looks extremely deep. Like it is 3 or 4 2x4's thick. I used a spade bit with a long extension just to get a small hole. I will have to install the conduit in small sections with pvc couplers because of ceiling height. (No room to drop a 10 foot section in without hitting the roof). So the hole will need to be the diameter of the coupler which is about 2 3/4. Also, where i need to put the hole is right beside 2 electric wires that drop down this wall into the panel.
What is the best, easiest way to cut this hole and to ensure it
stryped is offline   Reply With Quote
Old 11-18-2009, 10:27 AM   #2
Remodeling Contractor
move the wires out of the way. Use a spur bit with an extension. [IMG]file:///C:/Users/Bob/AppData/Local/Temp/moz-screenshot-1.jpg[/IMG]
Old 11-18-2009, 08:15 PM   #3
Four smaller holes at the corners and a sawsall to cut out a square.
Or a rotozip.
Make it big to give yourself room to work.
220/221 is offline   Reply With Quote
Rotted sole plate in bathroom firemanter Carpentry 3 05-30-2013 03:14 PM
Cutting into top plate. Clutchcargo Building & Construction 1 11-02-2010 06:59 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 07:42 PM
