Help! Do They Make This In Black??? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 03:45 PM   #1
Help! Do they make this in Black???
http://www.lowes.com/pd_31567-334-27...roduct_price|1
I already ordered and received our new faceplates assuming that they made this in all colors. Are there ANY manufacturers that make this in black? I can't seem to find any.
Thanks for your help.
Todd
toddmason is offline   Reply With Quote
Old 03-18-2013, 04:55 PM   #2
Rewards Points: 95
You might be able to order from home depot or lowes website (I think I have seen switches in different colors on the websites). If not, then you could go to House of Antique Hardware or Van Dykes. Both are restoration hardware suppliers and have websites. They carry all kinds if things, including colored switches and outlets (and not just antique, but also modern). They are a little high, but worth it if you need the part. Hope that helps.
Centex2011 is offline   Reply With Quote
Old 03-18-2013, 05:46 PM   #3
Thanks Centex. I'll try some of the others. Don't see it on Lowe's or Home Depot.
Old 03-18-2013, 06:05 PM   #4
Rewards Points: 127
Neither Cooper nor Leviton make that type of switch in black, closest you're going to get is brown.
Chokingdogs is offline   Reply With Quote
The Following User Says Thank You to Chokingdogs For This Useful Post:
toddmason (03-18-2013)
Old 03-18-2013, 06:23 PM   #5
I think the problem is that black is modern and the wide style toggles are modern. You want a modern color in an old fashioned style. If you're lucky enough to find it, you'll probably have a problem the next time you have to replace it.
Dorado is offline   Reply With Quote
Clear Heart Cedar turns black DMAGNER Painting 3 08-21-2012 01:45 PM
Two black wires and two white wires in a ceiling mshaw11 Electrical 6 07-11-2012 10:57 PM
Two black wires in ceiling fixture majch Electrical 3 06-20-2012 03:56 PM
GE SunSmart Timer 15312 Install Issue stringzz Electrical 10 02-06-2012 09:17 PM
Poly Gasline to replace Black Pipe? GabeD Plumbing 9 08-29-2010 12:47 PM
