Help With Disconnecting - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2009, 10:16 AM   #1
Help with disconnecting
I need to totally disconnect a commercial 4 bulb fluroescent light which is at the end of a run. What do I do with the remaining wires? Thanks
AlSmith is offline   Reply With Quote
Old 05-20-2009, 11:40 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Mount a junction box and put a cover on it.
Or remove the wire back to the last working fixture.
Old 05-20-2009, 12:56 PM   #3
Cap each wire individually?
Thanks for responding.
What is the safest method: Capping each wire with a wire nut and putting them in the junction box or put the wires together with one wire nut and put them in the junction box?
Thanks again.
Old 05-20-2009, 01:06 PM   #4
Rewards Points: 1,418
Do not connect together the wire ends that used to feed the light (!)
That will cause a short circuit.
Use a separate wire nut for each wire end. You will probably need electrical tape to keep the wire nut from fallling off. Several layers of tape and no wire nut will work too.
I suggest leaving the wire there in case the next owner of the house wants to use it.
Old 05-20-2009, 02:24 PM   #5
You guys are awesome!
Old 05-20-2009, 07:57 PM   #6
joed's Avatar
Rewards Points: 11,560
If you are going to leave the live wires in a capped junction box that box must remain accessible. You can not bury it under drywall.
Disconnecting from Circuit Breaker ckdiesel Electrical 15 03-16-2009 11:42 AM
More Clarification on Detached Garage Sub-Panel williamj001 Electrical 18 02-08-2009 01:06 PM
no disconnecting means at the electrical service entrance Denhamjw Electrical 34 06-30-2008 08:36 AM
Subpanel installation in outbuilding fls Electrical 19 03-16-2008 03:19 PM
Rookie disconnecting kitchen plumbing bcarwell Plumbing 2 02-14-2008 12:29 PM
