Help With Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 05:42 PM   #1
Rewards Points: 155
Help with dimmer switch
Situation:
I just changed out the two lights over the kitchen.
Problem:
It had a dimmer and now its just on/off and no longer dims.
The left light was a single wire connection while the right light had two wires.
i made sure the reconnect everything like it originally was.
the only thing i noticed differently was that the old lights had a white wire, black wire and a green wire (which i assume is the ground)
the new lights had just a white and black wire coming from the bulb.
is this crappy electrical work or is the light not meant for dimming?
yes i am an absolute novice.
rygar is offline   Reply With Quote
Old 01-27-2013, 06:01 PM   #2
joed's Avatar
Rewards Points: 12,332
What type of lights were the old ones? What type are the new ones? CFL lamps are not normally dimmable. LEDS also are normally dimmable. The LED and CFL that are dimmable need special bulbs and dimmers.
Old 01-27-2013, 06:05 PM   #3
Rewards Points: 155
i did chang eout bulbs....great news.
Old 01-27-2013, 06:30 PM   #4
Licensed electrician
Rewards Points: 1,456
The dimmer may be fried.
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 01:28 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 03:26 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
