Help With Digital Timer Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2008, 12:36 AM   #1
Help with digital timer wiring
I was hoping somebody with more knowledge than me could help with wiring a Frontier Timer for water heater. The heater has 3 green, black & Red color. The timer has 5 connector name,
1. Live
2. Neutral
3. (Dunno)
4. NC
5. No
I'm using 240V/16A here,
This is a link to the timer manual
http://www.mtspowerproducts.com/down...%20art%201.pdf
Any Idea? Thanks for help.
longman is offline   Reply With Quote
Old 12-06-2008, 12:48 AM   #2
Don't understand the problem---
NYCtinman is offline   Reply With Quote
Old 12-06-2008, 12:57 AM   #3
I mean how to connect...
thanks
Old 12-06-2008, 01:21 AM   #4
What I mean is the manufacture should have a wiring diagram i.e. -black & white(red) are live & neutral no= normally open nc= normally closed witch go to the limit switch (green) also check to see if they intend for an axillary switch
Old 12-06-2008, 06:53 AM   #5
Are you the UK?
jerryh3 is offline   Reply With Quote
Old 12-06-2008, 07:33 AM   #6
ya, m from london
Old 12-06-2008, 10:47 AM   #7
According to the wiring diagram in the rightmost pic.,
Terms 1 & 2 need 240v all the time.
Term 3 & 5 is normally open, 3 & 4 is normally closed.
Almost always you'd use 3 & 5 in series with the load and with the 240v power.
I suppose they supplied you with mating female connectors for these connector pins? Don't solder to these terminals unless they say you can.
Old 12-06-2008, 11:22 AM   #8
Originally Posted by longman View Post
ya, m from london
Is this from a Ravenheat Bolier?
Water Heater Timer Wiring? brentjroberts Electrical 2 11-05-2008 01:41 PM
Help with electrical timer wiring Jack417 Electrical 2 07-05-2007 02:26 PM
Digital timer problems bazzer Electrical 4 11-20-2006 05:44 AM
