-   -   Help with digital timer wiring (http://www.diychatroom.com/f18/help-digital-timer-wiring-33245/)
longman 12-06-2008 12:36 AM
I was hoping somebody with more knowledge than me could help with wiring a Frontier Timer for water heater. The heater has 3 green, black & Red color. The timer has 5 connector name,
1. Live
2. Neutral
3. (Dunno)
4. NC
5. No
I'm using 240V/16A here,
This is a link to the timer manual
http://www.mtspowerproducts.com/down...%20art%201.pdf
Any Idea? Thanks for help.
NYCtinman 12-06-2008 12:48 AM
Don't understand the problem---
longman 12-06-2008 12:57 AM
I mean how to connect...
thanks
NYCtinman 12-06-2008 01:21 AM
What I mean is the manufacture should have a wiring diagram i.e. -black & white(red) are live & neutral no= normally open nc= normally closed witch go to the limit switch (green) also check to see if they intend for an axillary switch
jerryh3 12-06-2008 06:53 AM
Are you the UK?
longman 12-06-2008 07:33 AM
ya, m from london
Yoyizit 12-06-2008 10:47 AM
According to the wiring diagram in the rightmost pic.,
Terms 1 & 2 need 240v all the time.
Term 3 & 5 is normally open, 3 & 4 is normally closed.
Almost always you'd use 3 & 5 in series with the load and with the 240v power.
I suppose they supplied you with mating female connectors for these connector pins? Don't solder to these terminals unless they say you can.
jerryh3 12-06-2008 11:22 AM
Originally Posted by longman (Post 194629)
ya, m from london
Is this from a Ravenheat Bolier?
